Hi Roy, I can not find the service manual for this TV,
Is it an overhead TV? if so, it would seem that it is out of alignment of the LCD cells
Try disconnecting all the TV's devices and see if the same happens when you put the menu?
It does not seem, a problem of interference, so it is observed in the photo
I await your comment
Greetings Franco Dosil
Hola Roy ,no encuentro el manual de servicio de este televisor,
Es un TV retroproyector? si es as?, parecer?a que esta fuera de alineaci?n de las celdas LCD
Probo desconectar, todos los aparatos del televisor y ver si ocurre lo mismo cuando pone el men??
No parece, un problema de interferencia, por lo se observa en la foto
Espero su comentario
Saludos Franco Dosil
SOURCE: NO VIDEO
I have a Samsung 50" plasma, that has been blacking out over the last 6 months. A 9/2005 set. Now its practically unwatchable as it happens 3 times in an hour. Its not heat related - I have a high volume 9" fan activated on TV power on. Turning the set offf/on usually makes it come back for a now short while. Considering to go put it in the back of my pickup and park it in front of Best Buy and discourage Samsung purchases. This is the 2nd Samsung TV I've purchased (the other a 32" tube) I gave to my folks a couple years ago and its gone bad as well. Samsung product may look good, but their video engineers are not.
SOURCE: TV not finding Digital Channels from Cable Box
We have Comcast and we plugged the cable straight into our Bravia, searched for Digital Channels and it found 131. We actually get all the HD channels that we had using the box, plus a few more. It's worth a try.
SOURCE: Channel keeps changing to 'Input 2' even when playing DVD
Have you taken the remote control out of the room? Try changing inputs from the TV.
SOURCE: my monster power HTS 1000 has a loud buzzing
take it back to the sort where u bought it from and they should replace it with a new 1
