Simple Steps That Can Fix Printer From Printing Blank Pages:
· Press the button next to Menu option.
· Now click on the button next to Test menu.
· Click on More.
· Locate the option for print fonts.
· Click on the key next to PCL.
· Now the device will print the font list.
If you still get blank printed pages, there might be some other issues as well which needs to be sorted out at first. There can be issues in software or hardware which needs to be found out and that can be resolved by professionals. If you need any such help, you can call on our Xerox Printer Support Number +64–48879116. We will help you with the solution at any day and anytime.
SOURCE: printing & copying blank pages
There is a problem with your transfer/seperation unit.
open door to the right look at the black assembly on the door it has a black spongy roller, is it in place? does it have a spring action when you push on it?
if yes for both your High Voltage Transformer ( HVT) is bad.
SOURCE: can anyone help I have
About a 95 percent chance that you have a bad print head.You can try cleaningn cycles and also jet substuitution but your problem is blocked jets.
You could have a piece of paper between the drum and print head.
SOURCE: Pages printing blank
Resolving white, light lines or streaks (eliminate light stripes)
From the printer, print the Troubleshooting Print Quality Pages.
With Troubleshooting highlighted, press the OK button.
Scroll to Print Quality Problems by pressing the Up or Down Arrow button. Press OK.
Scroll to Troubleshooting Print Quality Page. Press OK.
Evaluate the Light Stripes Test page for missing printhead jets (missing cyan, magenta, yellow or black color bars).
Clean the maintenance unit's wiper blade and empty the waste tray. A dirty maintenance drawer wiper blade can cause white lines and weak or missing printhead jets. Using a clean lint-free cloth or a paper coffee filter, gently clean the blade with a wiping motion across the entire length of the wiper blade.
SOURCE: Canon iR C6800 prints leading and trailing blank pages
There is an option in the print driver to print a separation page (typically just a blank page unless you specify otherwise) so that each person's print jobs can be differentiated easily.
This option probably got enabled somehow on her PC. Have her go into the print driver's properties (right click on the Canon in the list of printers and select Properties) and look for the option that says separation page or separator page and deselect it. Then click Apply or OK, and it should be good.
SOURCE: how do i print labels
Try using MS Publisher in making labels... create 1 and it automatically duplicates everything ...
