Air is blowing out between the dirt canister and filter
SOURCE: Dyson collecting debris/hair, ect on top of hepa filter?
Called Dyson today about the cyclone canister clogging in my DC17 Animal. Turns out it's a problem with the black rubber gasket in the bottom of the canister. This also causes the HEPA filter to get lots of dirt and debris on top of it. They are sending me a new Cyclone canister with the corrected gasket. This will prevent anything but small particles of dust from entering the top of the cyclone and the HEPA filter should no longer collect all that stuff. Hope so!
SOURCE: Replacement filters for Durabrand Canister Vac with HEPA Model# DB9191
The Durabrand filter can be found at http://www.totalvac.com/accessory/parts/H19030.html
SOURCE: how to replace dyson dc17 post motor filter
You do not have to disassemble the vacuum to get to the post motor filter. The above person does not know the DC17 if they are telling you this.
You simply remove one Phillips head screw, it is Phillips because most consumers won't have a T-15 driver at home. Remove that screw, the cover pops off and you take out the filter and replace it.
Easy peasy
SOURCE: Hepa filter stopped on Hoover Windtunnel 2 Model #U8361-900
This has a simple solution IF you have a air compressor with a high pressure nozzle. Outside the house, first remove the Dust bin completely and lay the unit down with the dust bin area up. now start blowing the nozzle at the hepa filter, Alot of dust will come out. Now start to rotate the filter while blowing the dust out. The filter will move one way easier, When there is no more dust reinstall the dustbin and check the suction and the rotation of the filter.
Tony
SOURCE: Does my Dyson Animal vacuum have a hepa filter?
The HEPA filter is not a cleanable item. The pre-motor filter is the washable one.
