The Panasonic PV-GS35 will let you record digital media to the mini DV cassette if the other video source has a DV input/output connection. Then you use the 4-pin to 4-pin Firewire DV cable, PV-DDC9 . This cable is available from Amazon, https://www.amazon.com/LETO-FireWire-Panasonic-Camcorder-PV-DDC9/dp/B00MLQVMSK , and other vendors. The digital camera doesn't have the S-video input needed to record from most other sources.
For information on the digital dubbing feature, see the manual starting on page 42. Panasonic has the manual on the product support page: https://shop.panasonic.com/support-only/PV-GS35.html . The current link to the manual is ftp://ftp.panasonic.com/camcorder/om/pv-gs19_en_om.pdf . See page 13 of the manual for the location of the DV port.
I hope this helps.
SOURCE: PV GS 35 wont play tapes from other cameras
perhaps it has to do with the SP and LP settings, I know certain video editing programs won't capture video recored in LP.
SOURCE: Describe your Panasonic PV-GS35 Mini DV Digital
There was an earlier post that explained the black ribbon between the LCD viewfinder and the body of the camera is split. You would have to buy a new LCD viewfinder for about $90 or send it back to them to fix for around $250. The same thing happened to my camera and I can actually is the split. If you close it down more than half way the picture shows up. I called Panasonic and they said you have to buy the whole LCD, that you can't just buy the ribbon. They don't even have a part number for just the ribbon. Good luck.
SOURCE: i want some software for editing panasonic pv- dv
If you want basic, non-professional editing capablities, and you use a Windows PC, try Microsoft Movie Maker, which may be downloaded here: http://www.microsoft.com/windowsxp/downloads/updates/moviemaker2.mspx and the user guide may be viewed here: http://www.microsoft.com/windowsxp/using/moviemaker/default.mspx
You might also look at a pay program, AVS Video Editor here: http://www.avs4you.com/AVS-Video-Editor.aspx
You just need a converter. here is one for you: Video Download Studio.
