Question about Acer Computers & Internet
CROWN JEWELL 11 SOFTWARE USED WITH THE ACER NOTEBOOK. IT SEEMS TO BE STUCK AND WILL WILL NOT QUILT MY PATTERN.
2 Suggested Answers
SOURCE:
SOURCE: How do I get patterns from the embroidery CD onto
Thank you - but I cannot afford to pay your rates - I went to a local sewing machine shop and got the advise for free.
Posted on Oct 01, 2009
The continuous binding pattern
Not sure what you are asking. Do you want to know how to cut your own binding? It is easiest to use a ruler and rotary cutter. Most often, the binding is cut on the bias. Bias binding wears better and has more flexibility when sewing it on.
There are some very handy methods to cut bias binding.
Continuous Bias Quilt Binding Step By Step Quilting Tutorial
Continuous Bias Binding 200 of binding from 1 2 yard of fabric
Sew Easy How to Create Continuous Bias Quilt Binding
Continuous Bias Binding EASIEST METHOD How To Whitney Sews
Apr 08, 2018 | Sewing Machines
Need instructions for quilt of simplicity #3795
More than likely you will need to purchase a duplicate of the pattern in order to get the directions.
Apr 05, 2018 | Simplicity Sewing Machines
My machine is adding loops under my stitches when I try to stitch a straight stitch, I am trying to machine stitch a quilt top!
Quilting is a bit more finicky than regular sewing. Be sure to ALWAYS RAISE the presser foot when threading the top thread. FWIW, I use a separate bobbin case for FMQ that I have tightened the tension to keep the bobbin thread from coming to the top of the sandwich, but I tend to use a finer thread for quilting so adjusting the bobbin takes care of it. In your case, however, it sounds like the top thread is staying under the fabric. I would try tightening the top tension. Also, install a brand new needle--a top stitch, embroidery, or microtex needle seem to work well for me. Test well on a sandwich made of the same fabric and batting and get it adjusted well before sewing on your quilt. Sometimes sewing speed will affect stitches under the fabric, or even on top.
5 Free Motion Quilting Problems and How to Fix Them
Correcting Sewing Machine Tension for Free Motion Quilting NQC
LOOPS Tension or Speed
https://www.generations-quilt-patterns.com/machine-quilting-thread.html
https://www.generations-quilt-patterns.com/sewing-machine-tension.html
https://www.generations-quilt-patterns.com/machine-quilting-tension-problems.html
Feb 27, 2018 | Sewing Machines
I got a new Brother 1634D Serger and would like to make a quilt on it. How do you get a 1/4 inch seam? please help me
Don't expect a quilt to be as accurate from a serger as from a sewing machine. First, you probably want to focus a strip quilt where rows of strips are stitched together. If you do strips, you won't have to worry so much about maintaining an exact 1/4" seam. You can also vary the widths of strips in order to camouflage any seam variations. Avoid a pattern that requires points being aligned! Any seam width variances will not as obvious as an error (it is intensive getting an accurate 1/4" on a sewing machine--so-o-o-o much more difficult on a serger). There are usually seam width marks on a serger that you can follow as a guide, but straight line serging is very difficult to accomplish. You can always try marking a line on your serger using painter's tape.
FWIW, making a strip quilt on a serger is a fast way of finishing a quilt. I divide my quilt into 3 or 4 sections, like making it in thirds or fourths. That way, when the quilt begins to grow, you are not constantly grappling with flipping or turning the heavy and bulky fabric. Instead, do each section separately, then stitch the sections together to make the whole quilt.
Also, be sure to press all the seams of a strip quilt in the same direction.
Strip Quilt Patterns
4 Free Strip Quilt Patterns That Standout from the Crowd Fons Porter
How To Sew An Easy Strip Quilt
https://www.quiltinaday.com/community/topic.asp?forum=2&topic=5481
Make FAST Serger Strip Quilt with 1 4 square Triangles
Feb 27, 2017 | Brother Sewing Machines
How do i make an x follow the oncreen progress of sewing a single run quilting pattern
Pantograph - IntelliQuilter® ' Computerized Quilting ...
www.intelliquilter.com/iQpedia/Pantograph.php
A pantograph pattern is one that goes from edge to edge, over the entire quilt ...patterns - there are some interesting combinations you can use to create ... Remember to align the on-screen quilt to the quilt on the machine before you sew (use the ...Touch Realign, and follow the on-screen prompts: Find a reference point on ...
Baby Lock: Ellure
babylock.com/sewing/ellure/
With a 5" X 7" embroidery hoop and a wide variety of built-in stitches and designs, ...With 120 frame patterns and a large library of built-in designs (including 40 ... cover so you see your progress and avoid running out of thread mid-stitch. ... Baby Lock IQ Technology is what makes Baby Lock machines so smart and efficient.
[PDF]Quilt Magician Manual updated 4-23-12.indd - TinLizzie18
tinlizzie18.com/images/Quilt-Magician-Manual-updated-4-23-12.pdf
This manual will cover everything you will need to know to RUN your Quilt ... Let's getto know your Quilt Magicianâ„¢... .... pattern boxes at one time, the system will onlyrun the pat- ... You can have as many patterns as you like in each pattern box. Circle for. Start. (X) for ... button and follow the on screen steps to re-calibrate.
[PDF]SideSaddle (SS) Users Manual - The Quilting Solution
Jan 11, 2016 | Sewing Machines
I need help with a quilt pattern
ask your question here by email:-
sewadvisors@nancysnotions.com
Jun 23, 2014 | Clover Trace n Create Quilt Templates with...
The top rod of my Crown Jewel baby lock quilting machine keeps slipping, what can I do?
I am quilting on a Crown Jewel and having trouble with the tension. How do I correct for skipped, gaps on the top threads? I have adjusted the bobbin tension.
Oct 25, 2010 | Baby Lock Imagine
How do I get patterns from the embroidery CD onto the machine. I have artista v3 and artlikn v4 but I dont know how to use the software with the CD of Latte Quilt
Sep 30, 2009 | Bernina Artista 170
I can't seem to set the time on my used tag heuer watch
Probably your watch has a screwdown crown and prior to attempt any settings you have to unscrew it. Some peoples fingers are stronger then others, so, try that with a pair of plyers. Cover your crown with a soft cloth and then grip with plyers(this will avoid any damage). Thread is right handed and unscrewing is done by turning the crown anticlockwise.
After setting the time don't forget to screw the crown back- it is for water resistance.
If you are unable to unscrew the crown, that means your watch is rusty and you will need watchmakers help.
PS If the watch is rusty, you can brake the crown off while trying to unscrew it. Don't panic yet, as in this case you will need a watchmaker anyway.
Don't forget to rate, please.
Jan 10, 2009 | Tag Heuer Watches
Damaged keycap - aspire 3690
If you look very carefully - you should see 'something like' an H shaped piece of plastic that holds the key in place - this controls the position.
You need to prize the legs that meet with the key away from the centre (carefully) using 2off small jewel screw drivers (maybe 2 off paper clips)
Aug 15, 2008 | Acer Aspire 3690-2196 Notebook
Computers & Internet Logo
29 people viewed this question
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
