SOURCE: i dont know where the temp gauge sensor port is
I'm pretty sure all GM's are the same. Look between the first 2 exhaust runners on the driver's side and you should find the sensor tucked in between the #1 plug and the exhaust manifold. Hope this helps.
SOURCE: have a 95 ford ranger 4 cyl need to know where
On the 4 cylinder motor (2.3L,2.5L), the coolant temp sensor can be located
on the left side rear of the engine, below the cylinder head.
A picture of a typical Coolant Temp Sensor (aka ECT) is below:
Be sure to partially drain coolant below the level of the sensor to avoid spillage when removing the old part. Best of luck on your repair!
Greg
