Question about Frigidaire Refrigerators
Frigidaire Childlock stuck on. I have held the button in for 3 seconds, nothing. I have turned the power off at the electrical panel, nothing. help!
SOURCE:
SOURCE: "3 second" light flashing
The 3 second flashing light is a lock that locks out all other functions. To disable, depress the 3 second light for 3 seconds and all the functions will be released. This feature is to use to keep little kids from starting the appliance.
Posted on Jul 04, 2007
SOURCE: Whirlpool Duet HT
Mine just did the exact same thing. I unplugged it, then plugged it back in, and it worked perfectly. Good luck!
Posted on Dec 10, 2007
SOURCE: Sansa e250 will not turn on
try buying a new charger and did you knw that you can also use a apple ipod charger
Posted on Mar 03, 2008
SOURCE: Pentax M20 Green Mode Stuck
i just had the same problem....
here's how i fixed it...
turn it on... then as it's loading up... hold the "menu" button
i think this forces it to stay on...
i changed the green button to be something else... not green mode
then i just turned it off and on again
Posted on Mar 11, 2008
  • 22 Answers
SOURCE: frigidaire electric range digital display light stuck on
Try turning the power off to the appliance for several minutes or un plugging it.
Posted on Mar 31, 2009
Control locked red light is on so nothing I can do to power it up and use. I turned the breaker off and on but nothing happened. What can I do to fix this?
If you are holding in Auto Dry Level for 3-4 seconds this should unlock the controls. If not, this usually indicates a stuck button on the control panel. Feel the push-in action of the Auto Dry Level button to see if it feels stuck or hanging up in any way. If the button feels right then this indicates that the user interface (touchpad) is at fault.
Oct 20, 2012 | Kenmore 6.7 cu. ft. Electric Dryer
My Olevia 37" LCD HDTV suddenly will not turn on.
power supply board is damaged,only working with standby power
Aug 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
I have a double draw dishwasher . the child lock key comes up and the dishwasher does not start
The lock button activates/deactivates the Keylock or the Childlock functions. This button has either a key or a padlock icon. I believe that on this model it is a padlock
Keylock
The Keylock feature disables all the buttons on the control panel.
To activate, press and hold the button until you hear one beep (3 seconds). The symbol
appears in the electronic display when the Keylock feature is activated.
Childlock
The Childlock feature locks the drawer and disables all the buttons on the control panel.
To activate, press and hold the button until you hear two beeps (5 seconds). The symbol
appears in the electronic display when the Childlock feature is activated.
To cancel the Childlock feature, press and hold the button until you hear one beep and the
symbol disappears from the electronic display.
This information can also be found in your product's Use and Care manual. If yours has been misplaced you can download or print one from Fisher and Paykel's website. http://www.fisherpaykel.com/customercare/userguide/index.cfm
If this doesn't work... And I've seen these units do some odd things. Try unplugging it for about an hour (if plug is not under sink you can turn of the breaker that powers the unit). Then plug it back in and see if that works. These dishwasher like many modern day appliances have solid state microprocessors in them which sometimes need reset just like a computer.
Hope this helps.
May 17, 2011 | Fisher and Paykel 23 in. DD603H SS...
KITCHENAID DISHWASHER SUPERBA MODEL KUDS01DJSS0 CHILDLOCK DOES NOT OPEN .REMAINS IN LOCKED POSITION EVEN AFTER POWER RESET. CAN'T USE THE DISHWASHER.
The easy solution is to try pressing the Energy Save Dry button & hold it in for 3-5 seconds. This should turn the child lock on & off.
If this doesn't work, then it's likely that one of the pads on the control panel is stuck, and it (the control panel) will have to be replaced.
If you don't have the manual, you can download one here (PDF format). Good luck!
Mar 02, 2011 | Dishwashers
Error code E 68
A button is stuck and it needs to be unstuck. Enter key test mode during the diagnostic test mode to determine which keys is stuck.
Press and hold Select and Cancel buttons simultaneously for 6 seconds to reset the control.
The buzzer sounds then immediately turn the cycle selector knob counterclockwise to the second position from the bottom.
Press and hold the Options and Cancel buttons simultaneously for 2 seconds then the control enters diagnostic mode. The buzzer sounds 3 times and the LEDs flash.
Turn the cycle selector knob clockwise the second position from the top. The drive motor runs and the heat source turns off.
The buttons can now be tested. Press each button and the corresponding LEDs turn on. You should be able to find which button is stuck. The Options and Select buttons turn on the same set of LEDs and also the Cancel and Start/Pause buttons.
Access the control and unstuck the button. Disconnect power and remove the top panel by removing the screws attaching it to the rear of the dryer. Slid the panel rearward and lift it off the cabinet. The screws attaching the console to the cabinet are exposed. Remove the screws and disconnect the wire harnesses then remove the console. The control can now be removed and the buttons are exposed. Unstuck or clean the stuck button contacts. It is recommended to clean all other button contacts to prevent the recurrence of the same problem in the near future.
Oct 28, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Whirlpool Washer WFW9400SZ00 No Power, Controls Button Works
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Press "end of cycle" for 3 seconds, wait for 2 minutes & try the door. This is your childlock feature, do it again and the machine locks.
How abt a nice rating?
Sep 07, 2009 | Whirlpool GHW9400 Duet Washer
Frigidaire electric range digital display light stuck on
Mar 30, 2009 | Frigidaire Kitchen Ranges
I HAVE A FRIGIDAIRE LEQ640SQ ELECTRIC DRYER
you may have a problem with the motor. this is the only device that would turn off the whole machine for 3-5 seconds.
there is this contact switch that would be held close by the motor once the motor is running normally until you reach the end of cycle.
but if there is problem with the motor, it has this over current device that would turn it off.
once off, the contact that it was holding to keep the unit running would open up and stop the unit from running.
tnx 4 using fixya,
drcool
Oct 19, 2008 | Frigidaire FEQ1442ES Electric Dryer
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
Carmen Mikulic
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
