TURNTABLE DOES NOT TURN..WHERE SHOULD I LOOK FIRST?
THOMAS FACCONI MODEL #TPC-7470CH MANUFACTURED JUNE 2001
    New Friend:
    Problem Solver:
  • 7 Answers
Check the belt- if it is a belt drive turntable.
Posted on May 19, 2019
SOURCE:
  • 3 Answers
SOURCE: Thomas Pacconi Model TPC-MSE-800 turntable
Pjam,
Had the same problem & checked around on the net. Several people tried replacing the belt, but it had no effect. Spoke w/ several repair shops around the country and they concur with what I'd read on the net - bad motors. 3 or 4 repair/supply shops told me getting a motor would be impossible. Since I only listen to 33-1/3 LP's, I messed around w/ it a little and found a solution. Take the turntable out of the unit & you will find a small circuit board attached to the bottom. On that board is a small square blue fixture w/ a white circular "dial" in the middle (has grooves to accept a small straight blade or a phillips screw driver). This controls the voltage to the motor, which in turn controls the motor RPM's. If you set the selector switch to 78, you can experiment /w turning that white circular "dial" to slow the motor down. It isn't very hard to get the speed set properly. The down side is that you will only be able to play 33-1/3 LP's, but they are probably the most common anyways. I assume you could do the same to set the speed for a 45, rather than a 33-1/3. Down side is that you will only be able to play 1 size LP on the 78 speed setting, but it's an easy adjustment that can keep an otherwise in-op turntable functioning. Good luck!
Posted on Jan 21, 2011
  • 3 Answers
SOURCE: I have Thomas Pacconi turntable which is about 5
BAMOUT
  • 2478 Answers
SOURCE: power supply for a thomas pacconi model tpc-hd-12 ser number 060800521
These people may help you.
www.turntable-power-supply.com
Posted on Nov 28, 2011
thammett1437
  • 6 Answers
SOURCE: i want /need a drive belt for tpc=hd-12 turntable
ebay.com
I’m happy to help further over the phone at https://www.6ya.com/expert/troy_065b1fb8718d7670
Posted on Oct 17, 2016
  • 52421 Answers
SOURCE: Ematic Set Top Converter Box, Model: AT103B, Manufactured date: June, 2016.. I need the programming codes to connect this to a Magnavox Universal Remote, Model: MC345, Manufactured date: June 2017
Applicable codes would be in your Magnavox remote control, if it is compatible.
Posted on Feb 23, 2018
I have a Thomas Pacconi Model TPC-MSE-807 turntable. The Power/Volume Control has gone on it.
Look on the data plate to see if there is a voltage and current draw value on it. The switch should be rated at 120 Vac @ 10 A.
Feb 02, 2017 | Dual Audio Players & Recorders
Ineed a turntable belt for tpc-hd 12
Fixya is not a buying service. Try an internet search for turntable belts.
Oct 17, 2016 | Audio Players & Recorders
I have Thomas Pacconi 3-speed phonograph model TPC-7475 and wanted to attach external bookshelf speakers. Is there any way to hook speakers up to the line out jacks?
You need to buy the Jack's male plugs, Wal-Mart has them if memory serves, and splice your speaker wires onto them, preferably with a soldering gun and heat shrink insulation.
Jan 12, 2015 | Seth Thomas Pacconi Turntable
Thomas pacconi # tpc-mse-800-o (no power)why is there no power getting through hole unit?
Since you have no sound even on radio, it's not going to be a bad tt motor. There is no fuse except for a thermal fuse inside power transformer. I would start with a continuity check accross both of the blades on the plug. If it's open, you prob have a bad power transformer.
Sep 06, 2014 | Seth Thomas Pacconi Turntable
Thomas Pacconi TPC-MSE 800
could you include a picture of the under side of the turn table where the belt is fitted?
May 21, 2014 | Seth Thomas Pacconi Turntable
CD player will not work in my Thomas Pacconi TPC-MSE-800
I have the same unit. Where do you find the screws that hold the cd clamp cover?
May 15, 2012 | Audio Players & Recorders
27 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
