SOURCE: Water smells like mold
seems to be a leak in the inner shell of the water heater, the outer shell is holding the stagnent water
SOURCE: Smelly water from electric hot water heater 40 gal.
turn the power off and flush it out by letting the tap run for an hour or so
i think it could have lime scale in it or the element is about to blow if its the type that you can get the top off look inside it you may see the fult even kettle cleaner may be needed to clean it out, but dont go drinking that water???
SOURCE: Solar with electric back up hot water tank.
Hi, Here is a tip that will help you...
http://www.fixya.com/support/r4654730-electric_water_heater_not_working
heatman101
SOURCE: we replaced our hot water tank a month ago and now
Water pressure is blowing everyting loose with new heater,give your system a good flush,it will work it self out. RichieRich
SOURCE: Water drips from the overflow pipe on top of the electric hot water tank Tank is a RheemGlas
1) Copy following link for troubleshoot and replacement:
http://waterheatertimer.org/How-to-replace-TP-valve.html
2) Add comment Mar 2013 and say what you discover
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
