GE WBSR3140DW Top Load Washer Logo
Posted on Aug 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My agitator is not working in my washer- it is a kenmore elite. the agitator seems locked up. Everything else works fine.
  • Anonymous May 11, 2010
    It is proably your transmission (expensive to repair) but take back off look in the bottom and see if any fan belt have come off
Anonymous
Level 2:
  • Expert 268 Answers
  • Posted on Aug 07, 2009
Anonymous
Expert
Level 2:
Answers
268
Questions
0
Helped
110374
Points
796
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Hope this helps.
Why is my washer spinning instead of agitating?
Check your cogs. Pull the top off agitator off and look inside.
Depending on model has different typed of cogs that slide and catch when working properly. The do wear out.
Also known as "dog ear cogs". Very cheap parts. $2.
Our Kenmore 110-21252110 Washing machine is not agitating, what could be wrong?
Wil,
IT could be the agitator dogs that are chewed up and not gripping like they should. I am including a link to the Sears parts direct website so that you can see what they are. Second link is to a video on how to change them.
Washer Agitator Dogs Part Number 3366877 SAME DAY SHIP GUARANTEE from...
How to repair the Agitator Dogs in your Kenmore or Whirlpool or etc Washer
22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
Kenmore Elite Frontload Washer not working
If you already changed the door lock the only other thing that controls that is the control board... It might be faulty.
1helpful
Kenmore 24732 will fill and drain but will not agitate or spin
HI, Even tho it drains ok, does it spin? If it doesn't spin or agitate, it could be the coupler that attachec the transmission to the motor.The agitator is ok, it is designed to work that way. Please let me know if I can assist you further.
Thanks
Vic
My kenmore elite oasis runs fine but wont go through spin cycle
Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
Ge elite 110 23012 100 top load washer
look on the inside your agitator makesure it not strip out cauing your agitator be lose might need to replace agitator
4helpful
Kenmore 70 series washer
the agitator dogs are problably remove agitator cap remove bolt holding agitator in ..dogs are part #80040
1helpful
2answers
2answers
Kenmore Elite King Size Top Load Washer
If your washer fills, agitates, drains, but will not spin, the likely cause is the gear case (transmission). A new gear case can run about $200 just for the part. With labor, this could be a bit expensive to repair. I hope this helps you some.
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
