Question about Food Mixers
Opened up the box with my new Kmix yesterday and out of the box, I can't tilt the mixer head to release the bowl.. Is there any transport protection or trick that we need to know about? Is it faulty?
SOURCE:
SOURCE: kitchen aid tilthead mixer will not lock down
The solution for both of these is a large screw that sits at the base of the head where the head and the base meet - you'll see it when you tilt the head up. This screw should not be all the way in. You can adjust how low the head goes- in the case of your blades hitting the bowl you'll want to let the screw out a bit; in the case of the locking, you'll want to screw it in a bit more.
Posted on Mar 17, 2008
SOURCE: Sunbeam Mixmaster Heritage series
I hope this helps. I found on mine that the rear screw on the "neck" had become slighty loosecousing the release to not fully disingage. I had to remove the dome shaped cap in the middle of the speed control knob, pops off fairly easy, to gain access to the nut to tighten it. Hard part was trying to hold the screw head still while I used a small screw driver and small hammer to tap the nut tight, very limited space between the "neck" and motor body.
btsctn
Posted on Oct 22, 2008
advacak
  • 125 Answers
SOURCE: New kitchen aid Beater does'nt fit
you got the wrong beater
Posted on Dec 31, 2008
SOURCE: Mixer won't tilt back
You may need to remove the head from the base to find the problem.  This is a simple procedure, and is easily reversed, so if it doesn't help you, you can just put it back and take it to a repair shop later.
To remove the head:
First, make sure to unplug the mixer unit!
Next, turn the unit upside down.  Inside the neck, you will see a screw.  Use a slotted screwdriver to loosen (turn counter-clockwise) the screw a few turns.  This will release the pivot pin on which the head swivels.
Push the pin out from one side using a long, slender implement (a screwdriver, pen, etc.).  With the pin removed, the head will lift off of the base, and you may be able to determine the problem from there.
Best of luck!
Posted on Jan 01, 2009
ginko
  • 19396 Answers
SOURCE: My mother needs a replacement bowl for a Model 4C Hobart Mixer
Hi.
The Hobart/Kitchenaid model 4C Stand Mixer was produced between 1961 and 1977.
This unit is now a vintage piece chased by collector. Parts dealers do not sell parts anymore for such an old model.
The parts must be purchased on the second hand and vintage market, best source is Ebay. Put 4c mixer or kitchenaid 4c to find parts.
The bowl is easy to find, it is part 4162158, regular retail price for replacement is $44. buy the glass one on Ebay, that will be the original one mounted on first models.
Here Ebay list.
Vintage KitchenAid 4c Glass Mixing Bowl Excel Cond!
VINTAGE KITCHENAID 4C MIXER WIRE WHISK ONLY
KitchenAid Mixer md 4C Complete with Bowl White
KITCHENAID MIXER 4.5QT S.S. BOWL FTIS MODEL 4C 4162158
Here also a forum where you can contact more Kitchenaid vintage appliances owners or collectors.
The dough tool is not even easy to find on Ebay. Try contacting Kitchenaid and see if they can give you a compatible part.
If they have the original one (unlikely) , then do not be surprised if part price is over $30.
If you find a 4c with tools for spares on Ebay , buy it, and resell the parts you do not need. The whole mixer with bowl and one tool is worth over $50.
The original owners manual can also be purchased from Kitchenaid/hobart
Regards.
KitchenAid Customer Service
Posted on Nov 13, 2009
How to fix my kitchenaid mixer hit bowl?
The height of the beater to the bowl is adujsted by the screw found when you tilt the head back.
Service Manual:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
May 26, 2014 | KitchenAid K45SS Classic Stand Mixer
My dough hook is stuck in my K mix kmx50.
yes the dough hook is a firm fit on those
Instruction Book KMX50, KMX59 English - Kenwood
www.kenwoodworld.com/.../Instruction-Manuals/kMix.../kMix.../18362iss2%20KMX..
Apr 29, 2017 | Kenwood Kmix Kmx50 Stand Mixer, White
The mixing section has a gap in between
Do you mean the beater is not touching the bottom of the bowl? AS in there is a gap between the beater and the bottom of the bowl so it is not mixing all the ingriedients?
If you have a Tilt-head style mixer, you can adjust the beater/bowl clearance by turning out the adjusting screw. Place your bowl on the bowl screw cap, Place the flat beater on the agitator shaft and lower the head of the mixer so the beater is at the bottom of the bowl. There should be a 1/16" clearance between the bowl and the beater, if the beater is too close to the bowl turn in the adjusting screw, and if the beater is too far away turn out the adjusting screw. The adjusting screw can be located by tilting the head of the mixer back, and in the neck of the mixer you will see a flat head adjusting screw.
However if you have a bowl lift mixer and the bowl is too far from the mixer there are a few different way to fix that problem. If the bowl and beater are too far apart start by adjusting the adjustment screw. On this mixer the adjustment screw is under the head. Remove the bowl, and beater and lay the mixer on its back. You should be able to see under the head a screw sticking out, it does not have a head, but a little slot in the screw, use a flat head screw and adjust the beat 1/4 turn. Put the beater and bowl back on and test mixer to see if it the beater has a 1/16" clearance. If it doesn't adjust the screw and 1/4 turn. If after adjusting the screw the beater and bowl still have too much clearance use a mallet and tap both sides of the yoke arm up evenly until 1/16" beater to bowl clearance is met.
You can use the same dime test in the bowl to make sure you have the correct 1/16" measurement for the beater/bowl distance.
Thank you,
Colleen
MendingShed.com
800-339-9297
Apr 30, 2013 | KitchenAid Food Mixers
Is a kitchen aid model # KSM5PSAC the same as KSM150SP?
The KSM5 and the KSM150 are different mixers. They are both 5 quart mixers and use the same gearing and motor. However the bowl design is different. The KSM5 is a 5 quart bowl lift, which means the bowl locks into the arms of the mixer and raises towards the head of the mixer, where the ksm150 mixer is a artisan mixer, which is also a 5quart mixer, but the head of the mixer tilts back and the bowl twists into the base ring to lock into place. These two mixers will take different bowls and beaters.
Thank you,
Colleen
Customer Service
MendingShed.com
Jan 27, 2013 | KitchenAid KSM150PS Artisan Series Stand...
I received my mixer as a gift for my birthday in October. The bowl gets stuck and does not release from the base. I have to hit it a number of times with a rubber mallet to get it to release. Also when...
If that is the bowl that came with the machine it is not wrong. What happens from time to time is that the head on the mixer automatically adjusts causing the beater to not operate as it should. To adjust the head on the mixer place a dime at the bottom of the bowl, attatch the beater to the mixer and make as if you are going to start mixing. The beater should JUST touch the dime. If it doesn't touch it at all or is pressing it against the bowl, tilt the head of the mixer up to locate the adjustment screw located inside the shaft. Take a flat head screw driver, turn the screw clockwise (to lower the head) or counter clockwise (to raise the head). Place the beater back on the mixer, turn the machine on and see if it moves the dime moves. Once it is properly adjusted the dime should move ever so slightly.
Nov 19, 2010 | KitchenAid KSM150PS Artisan Series Stand...
I cannot unlock the mixer to release the mixture in the bowl, suggestions?
I am guessing you have the type of mixer that the head tilts back on. I would suggest loosening the bowl by tapping the handle to undo it. I usually use the palm of my hand to tap it. I am guessing the mixture is quite thick and loosening the bowl should allow the head to lift. I am also guessing that the pin that holds the head to the body and acts as the hinge has slipped out of place. It should be equal on both sides of the mixer. If it isn't, knock it back into position then tighten up the screw under the base that holds it in position.
Jan 25, 2010 | KitchenAid Food Mixers
Doesn't mix in the bottom of mixer
Using the tilt release switch, tilt the head all the way back. This will expose a large screw inside the hinge which you can turn both ways to either get the beater closer or further away from the bottom of the bowl - can't remember which way is which, though. (I had the exact opposite problem: the dough hook was grating on the bottom of the bowl.)
Hope this helps. Have a happy Christmas
Dec 21, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Instructions for Sunbeam 2350 Heritage Series Mixmaster
Go to sunbeam.com, select "kitchen", then select "customer service", then "instruction manual", then "stand mixers", scroll down to model #
Nov 23, 2008 | Sunbeam 2350 Heritage Series Mixer
Kitchenaid Mixer head wobbles bad
The solution provided by luannej is useful only if your mixing attachment is striking the surface of the bowl. By adjusting the screw located at the junction of the head and base, you are actually controlling how far the head is allowed to tilt forward and, thus, the height of the attachment above the bottom of the bowl. Although the attachment striking the bottom of the bowl will lead to wobble (and noise!), it isn't usually the root cause of the wobble. In fact, the wobble may be causing the bowl strikes and adjusting the head height only hides the problem.
The head of the mixer is secured to the base by a large steel pin. Any play between the head and base comes from this hinge and its resulting tolerances. To "tighten" the sloppy tolerances causing your wobble, follow these steps: 1) Lock the mixer's head down and turn the entire mixer upside down. 2) Looking deep into the hollow base, find the small slotted set screw. This screw actually presses against the pin and takes up the slop between the head and pin. Note that this screw is not the large slotted screw I mentioned earlier visible when you tilt the head back. 3)Tighten the small set screw as much as you can. Your wobble should be greatly reduced or eliminated now. 4) Lastly, you may want to readjust the large screw controlling the head's tilt to optimize the distance between attachment and bowl. Hope this helps.
Oct 24, 2008 | KitchenAid Artisan Series Tilt-Head Stand...
Food Mixers Logo
47 people viewed this question
Top Food Mixers Experts
Bruce Showalter
eyecam
Marvin
Marvin
Are you a Food Mixer Expert? Answer questions, earn points and help others
