If you are using the correct shampoo then the tank my need to be replaced. They will clog if tank wasn't cleaned after last used. Check that the dial is open and both filters are in place , add water and shampoo and test without the hose connected . If you still have no suds coming out then just order a new tank.
SOURCE: Kirby Ultimate G carpet shampooer not producing foam anymore
I was having the same problem. There is a filter plug that came loose on mine and went down into the hose. It belong on the water tank and fits in there tightly and the hose end goes over it. That's what actually makes the foam.
SOURCE: shampooer won't distribute foam/soap evenly
Disconnect the hose from the tray - if you are getting good flow of the foam - I'd say you probably did not lower the shampooer all the way down.
If the foam is not being dispensed continuously - you may want to check:
1. Check the suds screen - make sure it is clean and installed in the tank and is clean f lint
2. Check the sponge where exhaust is inserted in the tank - rinse it. Also look for the clog under the sponge in the valve.
Good Luck
SOURCE: Can NOT get Kirby G6 shampooer system lowered to use
take the attachments off and see if you can lower it then..if so .lower the vacuum and put the attachmens on then try
