Every DW is a bit different. You have to pull it out of the cavity where it is installed. Turn off water and power first. remove the two screws at the top of the front face that anchor it to the counter. Remove the escutcheon at the bottom of the front . Typically there are two or four screws. Carefully pull it an inch or tow. Then look under with a flashlight and pull another few inches. Repeat until it is clear. Stop when you see the drain hose connection - I have owned back and front drainers. It is usually affixed with a clamp to the outlet. The other side goes to a drain of often the garbage disposer. Replace, reassemble. Good luck
