SOURCE: seiki has no picrure #se32hy27
Sounds bad my flat screened friend... without a history of a slow death or brand new out of box or friend sold it to me and said it would last for years smelled hot left on over the holidays for 96hrs straight no history at all I will have to say a logic digital I/O board with a minimum of $95 labor/service call/ troubleshooting.....but there\'s always a chance that the removable cord that plugs into the back of the TV has come loose and just looks like its plugged in(not the wall end) and the TV is to heavy to move and check quickly.... shot in the dark but not bad for "no picture" (could you be any more vague?) just kidding...good luck friend hope Iv\'e helped a smidge~~~> SC
Testimonial: "checked all plugs, is 2 mon old, can hear channels but no pic!!!"
SOURCE: seiki se32hy27
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
