SOURCE: I suspect someone is spying through my Alcatel one
Hi James
Of course it's possible.... You are using Android OS which has known security holes.
Many Apps that are so called "free" can be monitoring your keystrokes and IP Data. Any internet search will prove this.
As they say... "You get What You Pay For"
If security is a major concern then switch to a tighter environment like IOS8 type phone.
But you already knew all this.... Right!
Cheers
Trevor
SOURCE: My Alcatel pop c1 Android smartphone screen's not touching
Need more information to help you diagnose.
Has it worked before and stopped? Is this a new device that you are finding difficult to use?
If the touchscreen has become unresponsive to touch, and a reset or restart are not addressing the issue, it is likely to be a hardware fault.
SOURCE: Is the alcatel one touch fierce 2 compatible with Samsung kies ?
Why looking for Kies when Alcatel already have a softwear designed to work with its phones?
here is the link to download it:
ALCATEL ONETOUCH Support Android Corner
Did you get it wet?
It's a symptom of a bad circuit board.
SOURCE: How to pair Bluetooth speaker to one touch pop7 tablet?
If a Android OS you find the gear/setup, bluetooth and then tell it to scan. You need to make sure you turn the BT speaker on. The brand of speaker should popup on the tablet. Select it to pair.
