OK we know it's a Samsung Refrigerator probably 1 of about 50 models that Samsung sells. The model number is on a plate inside the refrigerator. If you don't have a user manual use the model number at searspartsdirect.com to view or
download the user manual. If sears has ever sold this model it will be there! Use the troubleshooting section to find out why it's beeping. It may be as simple as needing to clean the door seals so they don't leak air. Remove the light bulb cover if there is one and replace the light bulb with one of the same kind.
The light assembly housing may need cleaning. The extreme brightness of the light inside the housing will cause the plastic to give up some chemicals and coat the lenses inside with a residue that will show up as snow on the screen.
bad either inverter board for screen back light or busted back light.you will need to remove back cover to access the inverter board and back light inside.the back light is covered with plastic and metal shield located at the top and lower portion of the screen panel display.
if the red pilot light is blinking there might be a problem on the power supply section. have a repairman check it. It could be a blown capacitor. if no light is blinking and you don't here a clicking sound inside there might be short a circuit inside and the fuse is blown.
My pics come out too white, to light!!
I use to get Beautiful clear pics of outdoors and inside. They are completely white out side and very light inside!
I have tried everything.
I lost the manual too so Im screwed.
I run a business and need perfect pics to sell .
Please help.
Red Error Light Stays OnThe following conditions can cause the On Line LED to glow solid red:
Printer paper is jammed inside your printer.
A cover is not be closed properly.
The toner cartridge is not inserted properly and needs to be reinstalled.
The toner cartridge is running low.
There is no paper in the paper tray.
The paper inside the paper tray is not be installed correctly.
Red Error Light BlinksIf your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
