Vacuums Logo
Billie Holloway Posted on May 07, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the restart button on a power max xl dirt devil
Marvin
Level 3:
Top Expert:
  • Dirt Devil Master 85,242 Answers
  • Posted on May 07, 2019
Marvin
Dirt Devil Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29050883
Points
266281
I know of no "resart button"
5 Related Answers
Anonymous
  • 1673 Answers
  • Posted on Jan 06, 2008
SOURCE: Dirt Devil vacuum
You might unhook the belt, if it still sounds real loud, then the motor is bad and will have to replaced.
Anonymous
  • 310 Answers
  • Posted on Jun 11, 2008
SOURCE: Instruction Manual needed for Dirt Devil upright model 088305
http://geeksquad.fixya.com/ThreadView.aspx?prdid=89362&thid=642772
Instruction Manual needed for Dirt Devil upright...
Posted by Innahouse on Jun 03, 2008
Describe your problem I need an instruction manual for a Dirt Devil upright model 088305.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Dirt Devil Model #M088300 Upright Vacuum. The best idea is to contact the Royal Customer Service Dept and give them the model 3 and serial 3 of the unit you are requesting the owner’s manual for, I will give you the website address and phone # listed below:
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Robert Pagliaroli
  • 294 Answers
  • Posted on Jan 24, 2009
SOURCE: Dirt Devil Vision bagless not working
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Anonymous
  • 281 Answers
  • Posted on Apr 08, 2009
SOURCE: i cant get the power brush to work
can you turn the brush by hand? if it turns real freely the belt is broke or the brush siezed up make sure there isn't any carpet strans wrapped around the ends of the brush otherwise the brush won't turn.if its the belt make sure you clean the motor shaft before you put on the new belt,the old rubber from the old belt will make the new belt run unevevly and break again..good luck
Anonymous
  • 281 Answers
  • Posted on Apr 29, 2009
SOURCE: dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
the dirt devil featherlight has a automatic height adjustment for carpet and bare floors.check the wheels and see if there is something wrapped up around the wheels
4answers
I took my dirt devil power max/pet apart to clean.. now I can't remember how the adjustment wheels go back in ?
The best way to do this is by studying the parts diagram
https://www.google.com/search?q=dirt+devil+power+max+pet+parts+diagram
Or just carry it into the closest Dirt Devil Service Centre and ask them to 'service it'. It is not expensive.
There are no videos showing how this is done, but the video made me smile
My dirt devil propower xl is brand new. It cleans very good but stops after few minutes and never turn back on. What is the problem?
they have been having alot of problems with these models. if its brand new, take it back. don't try and work on it yourself, it will void the warranty
Height adjustment on dirt devil pro power xl vac doesn't work
sometimes vacs get to old ,, you can find the same model or purchase a new one here>>>www.discountbargainprices.com
The brush is not turning on the dirt devil power max and not sucking up any dirt.
The belt is probably broken or off the pulley. These will build up hair and rug fiber around d the moving parts and force the belt off. I don't know the exact access on this model but a cover will need to be removed. Some models require Phillips screw removal of complete upper or lower cover. Be sure to clean out all debris and re install or replace belt with new.
Why does my dirt devil max upright vacuum shock me? When im making laps, vacuuming.
if it is during vacuumming carpets it may be static electricity generated by the plastic head over the carpet
if it happening n hard surfaces , take it in for a safety check as there may be a loose wire touching metal and causing you the shock
My dirt devil max keeps shocking me, amnd it seems to get more oomph to it. Is there a groundbsomewhere that may have un-ground somehow?
1, stop using it its dandgerous, & 2 there is a short circuit, get it repaired or throw it away & buy a new 1
Do my Dirt Devil have a restart button it just stop running
Hi! No the vacuum doesn't have a restart button, but it does have a thermal protector that will shut the vacuum down when it is overheated. If your dirt cup was too full this will activate the thermal protector sensor. Clogs and dirty filters can cause this as well. We recommend emptying the dirt cup, tapping out the filter and checking the hose for clogs. The vacuum will come back on usually within 45 minutes to an hour. Hope this helps. If you need further assistance don't hesitate to reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil
Top Dirt Devil Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
NOEL
NOEL
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
