Question about Tools & Hardware - Others
How to load a gardener bender MSG-301 low voltage stapler
I have a Towa AX100. Can it still operate if the batteries holder is corroded? Error msg keeps showing BATTERY LOW.
if the contacts are corroded then the error message of batteries low indicates high resistance in the connections resulting in a low voltage reading
Jul 24, 2018 | Power Computers & Internet
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
Just bought and tried to load my Swingline Smart Touch low force stapler. Don't know how to get it opened
I have one of these models. Just push the gray lock mechanism at the end of the stapler and the loading magazine will pop out. The chrome plated magazine opens towrds the front....it slides forward and backwards.
Jun 17, 2011 | Office Equipment & Supplies
How to load staples?
  1. Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
  2. Load the heavy duty staples into tray.
  3. Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Resource 1 : eHow Article
Feb 21, 2011 | Swingline Heavy Duty Stapler 30 160 Sheet...
Gsw-22 nameplate data
It will handle a load of 6 amps when connected to 120 volts ac, or if connected to 240 volts ac, will only handle 3 amps load. Regardless of any rating on the switch, ALWAYS !!, SHUT POWER OF TO ANYTHING ELECTRICAL BEFORE WORKING ON IT.!! No hollering at you, just want it emphasized to be sure you stay safe, and alive. Look at what your powering with this switch for an amp rating on it. If amp rating is higher than switch is rated at, don't use it, in case of fire.
Apr 16, 2010 | Gardner Bender #GSW-22 Push Button Switch
Gardner Bender #GVT-392 Solenoid Voltage Tester manual where can i download one at
Google " gardner bender GVT-392 manual".... there is plenty of hits good luck
Dec 31, 2009 | Gardner Bender #GVT-392 Solenoid Voltage...
Need easy instructions on how to use GRT-3500 Gardner Bender
this voltage tester is simple to use. For instance, put one probe into each side of a receptacle and it will tell you the voltage there.
Jun 12, 2009 | Gardner Bender #ET6206 Heavy Duty Voltage...
Msg after entering service mode
There are 5 solutions for this problem
1) house voltage (voltage to low)
2) Inverter
3) Motor (if motor only turns in one direction)
4) wire connection to the low voltage
5) Hall sensor at rotor (only turns a 20% of speed)
let me know if I can help you more...
Aug 05, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Tools & Hardware - Others Logo
22 people viewed this question
Top Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
