Samely Mendez Posted on May 07, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What means Service call code SC565 on a savin C3030 printer?
Jim Keysor
Level 2:
Sergeant:
  • Expert 331 Answers
  • Posted on May 07, 2019
Jim Keysor
Expert
Level 2:
Sergeant:
Answers
331
Questions
Helped
83752
Points
605
That code is most likly fuser code, could be blown fuse, or fuser may have to be reset by getting into service mode, Yellow key 107 red key, now in svc mode. look for tab that says mode. depress and look for code to reset fuse coul be 5810 and depress excute. turn on off that should reset fuser if code comes back you have bad fuser, fuser, lamp etc.
5 Related Answers
Anonymous
  • 87 Answers
  • Posted on Mar 12, 2008
SOURCE: Savin C3030
SC 553 is a fuser overheat error. If you have a fuser great, but you will still have to reset the code. Clear modes, 1, 0 ,7, press and hold clear/stop key. Menu will change, select copy sp. From there, select 5, (mode), scroll till you get to 5810. Select it, and press execute, then exit back to copy sp. Select 7 (data log) then scroll until you get to 7807. Select it, and press execute. Exit all of the way out, and recycle the power.
If it comes to ready, great. Try it. If it codes out again, you have a problem, possibly thermisters, (in the fuser), power supply getting stuck on, I/O board not regulating the power supply. Could be any of these things.
But start by resetting the code. Could be a a thermister got some toner stuck under it, and the other thermister detected a difference. It really could be that easy.
Anonymous
  • 143 Answers
  • Posted on Sep 20, 2009
SOURCE: Can you number pages with a Savin C3030 without
Yes, you can load the documents in the tray, tell it to number them and copy a blank white original.
jknutson3813
  • 22 Answers
  • Posted on Dec 06, 2009
SOURCE: how to replace savin c3030
The used toner collection bottle is located behind the cover, just left of tray 1. To empty/replace this bottle, follow these steps.
  1. Turn machine off with red rocker switch, this is located on the left side of the machine.
  2. Open front cover.
  3. remove screw on the bottom-left side that holds the toner collection cover closed.
  4. close the front cover
  5. pull out tray 1
  6. open toner collection bottle cover(swings to the left)
  7. pull out toner collection bottle
At this point you can empty it or replace it, and reassemble in the reverse order of removal.
Anonymous
  • 287 Answers
  • Posted on Jul 11, 2010
SOURCE: touch pad control panel on Savin c3030 doesn't
Hello.I can ASSURE you absolutely what the problem is.Your Savin copier(which is a perfectly fine device) is actaully manufactured by Ricoh.I work for a Savin dealership and Ricoh contacted all dealers WORLDWIDE with the news that due to a manufacturing defect that the touch screens of al models such as yours WILL fail.They sent out free of charge replacement touchscreens to all dealers as they have a record of how many of what type was sold by whom.I mean we had a crate of touchscreens show up at our dock at about the same time we started to get a barrage of service calls for this problem. It was one of the wildest things I've seen.Now it is just the "glass" of the touchscreen that is defective as it actually an "active" part of the op panel's circuitry of the op panel.It is relatively easy to replace.Now the question is, how do YOU aquire one,as it is a known defect and is covered by warrranty.I have to assume you purchased this device on your own and that you do not have a service agreement thru an independent dealer.My advice would be to contact whomever you bought the device from or perhaps Ricoh directly and tell them the problem and that you are aware that Ricoh is aware of the problem and see what they say.I cant tell you how many of these things I have had to replace as it is not a matter of IF there will be a problem with the Savin c3030 touchsreen, but merely when.Good luck, and although I did not "FIXYA" I hope you will acknowledge to the sight that I gave you the facts that you need. :-) Take care
Anonymous
  • Posted on May 04, 2011
SOURCE: New internet service now Savin C3030 won't work
how do you change the ip address on a hp jetdirect 170XC
2answers
I replaced the black cartridge and I keep getting an error message to replace the toner on the Savin c3030
that would be a machine malfunction already try to see the entrance of the printer near the ribbon if attached correctly maybe some small parts have been malfunction near the cartridge slot
What is error code sc565?
If you wish to get some details; check the site linked here. Pull up older posts......
http://electro-medical.blogspot.com/
Savin C3030 copier. refilled staples, but copier thinks empty. How can I get the copier to sense the staple refill?
There is a sensor that tells the machine if there are staples present. Check to see if it has been moved out of position or if the wire going in has been broke or crimped
3helpful
Touch pad control panel on Savin c3030 doesn't work - the rest of the control panel buttons do just not the touch pad for any function?
2answers
Can you number pages with a Savin C3030 without actually copying the documents
Hello sir; Yes, there have SP mode it does the job,the procedure as follow; press "clear mode" + "107" thenpress and hold down for 3 seconds, then touch screen on copier SP, enter number 5212-003, 004 to open the program. press "exit" twice to end the service mode.
2answers
Reinstall the printer on your operating system. For example, Windows XP is probably still trying to print to the old IP address. You will need to find out the new IP address of the printer and tell your operating system to print to that new ip address.
2helpful
Savin C3030
Top Savin Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Ngoro
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
