Question about Frigidaire Washing Machines
How to fix frigidaire washing with error code i30?
I tried resetting it, but it did not work, so how do I change the hose which I know is too long when the repairman installed the hose
SOURCE:
IFIXALL
  • 869 Answers
SOURCE: Pause Error - Frigidaire Affinity LTF6000ES0
If you just paused the washer and now displays a error try draining any existing water all out of the machine.Before re filling it see if you still get the error message.I'll be happy to guide you through this.
Posted on May 21, 2008
SOURCE: washing machine error code on Frigidaire ATF6000E
thank you larkinator.. that totally fixed the problem as far as i can see right now, I am letting it "wash" a load of nothing. it was a bunch of BS how they hid the filter... I had to literally take apart my whole machine. :-) but its fixed, THANKS!!!!!
Posted on May 28, 2008
  • 174 Answers
SOURCE: how can I reset an i30 (flood control) error?
you have to mopp up any water in the base of the machine. this can be caused by a leak . a sagging pressure pipe to the pressure switch can do it as well. you can tie it up to stop the sag. its at the front behind the plinth area.
Posted on Jul 22, 2010
SOURCE: Dishlex 302 model is displating "i30" error which
i ahve the same problem! ANy solutions out there?
Posted on Oct 28, 2011
  • 132 Answers
SOURCE: What does error code 110 mean on an affinity Frigidaire washing machine and how do I fix it
Can`t find error 110.
What`s (not) doing?
https://removeandreplace.com/2014/10/28/frigidaire-washing-machine-error-codes/
Posted on Mar 16, 2016
Frigidaire Dishwasher has error code i30 and drain pump still runs even with door open. Tried power cycle and comes right back on running and error code i30.
Error Problem / Condition = Clogged filters or a restricted drain line has been detected. ... If the drain line is attached to a disposer, check that the knockout plug has been removed. Frigidaire Dishwasher Error Code = i30. Error Problem / Condition = A leak or over flow of water has been detected in the bottom pan.Feb 18, 2016
Frigidaire Dishwasher Error Codes - What To Check - How To Reset ...
https://removeandreplace.com/.../frigidaire-dishwasher-error-codes-what-to-check-how-t...
Text info here
Frigidaire Dishwasher has error code i30 Google Search
Jun 09, 2018 | Frigidaire Dishwashers
Why is there recurrent error code I30?
Hello Roberta, I appreciate your submission!
Based off the information you have provided me your Frigidaire dishwasher is displaying an error code of "I30". Error code "I30" means you could be experiencing an issue within the aqua control, which means it could be your water valve, water line, or control panel. You may need to reach out to your manufacturer for additional assistance. I hope this information is helpful. -Matt
Apr 19, 2016 | Frigidaire Gallery Series FGCD2456QF Full...
Error code i30 (leak). How to fix it?
Hello friend, I appreciate your inquiry!
Based off my understanding your dishwasher is displaying an error code of I30. An I30 error code means this could be an issue with your aqua control. I would suggest performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for at least ten minutes. If you continue to receive an I30 error code after the reset I would recommend having a professional technician out. This will help you avoid any unnecessary part purchases. Hopefully this information is helpful to you. -Matt
Dec 13, 2015 | Electrolux Dishwashers
Washer won't start showing code E31. Already changed pressure switch an cleaned drain. Is there a way to reset?
error code e31 frigidaire washer Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your error code e31 frigidaire washer question. ... error code E31, first check if it is a false error code by resetting the power to the appliance by ..
Jul 28, 2015 | Washing Machines
What is an i30 error code for frigidaire dishwasher
Hello friend, thanks for your inquiry!
On your Frigidaire dishwasher "i30" stands for aqua control. You should perform a reset on your dishwasher and that could clear any false error codes. To reset your dishwasher you can flip the household circuit breaker off for ten minutes. If that does not work you could be experiencing an issue with your water inlet valve or control panel. I hope this information has been helpful. -Matt
Oct 10, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire dishwasher fault code i30
Good Afternoon Friend,
I understand that you are receiving an i30 error code on your Frigidaire dishwasher. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and start your dishwasher. If this does not correct the i30 error code, I suggest you contact your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire Dishwashers
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
Won't drain...
on the pump there is a lint filter it is either in the drain hose coming from the tub or there is a slot on the pump that screws off.you have to take the front lower panel off to get to the pump after you take the junk out unplug washer for 60 seconds to reset computer. let me know what you find
Jan 17, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
