Subwoofer problem
The distortion you are experiencing could be due to a few things,
Drivers for the device,ie the latest updates applied recently,
This may affect the performance of the units functionality.
The cables not being connected properly,poor signals and connections,
The source from where you original sound signals came from,
ie,over recorded source,too loud for the system speakers to reproduce the correct tones,
this is dangerous to speakers and the listerners hearing comfort too,
The simplist way to check your speakers are ok is to check them on another system with a similar sound device,or plug a set of head phones into you creative 4.1 output on a low volume,
is there a signal output to your head phones???
The most comon form of distortion is the equaliser setting on the original source output,turn it down to help eliminate the frequency your looking for and the adjust EQ to suit your comfort zone.
Apart from this will be unplug each zone and test individually,
should be a quick and painless solution,
Microphone feedback can damage speakers too,,,,,,
If the distortion remains try different speakers on the output.
Hope this helps , MISTERDJ
