SOURCE: Unable to use Sky HD Due to an HDCP
Try calling samsung they might have a firmware update they can send you
SOURCE: 4 lo working, 4 hi stopped working , A4WD never worked
Hi my name is Juan and I do own a trailblazer with the same year 2002 and I read the problem you have let me try to help you Have you try to shift to 4hi with your transmission in neutral ? the transmission needs to be in neutral in order to shift the transfer case to 4hi and the vehicle needs to be completely stooped also is your service 4wd light on?? if the light is on your transfer case needs service and it can be as simple as the switch inside your car or a solenoid that has not been detected by the computer
SOURCE: only 1 battery charges
The lights are working, the batteries aren't. Red indicates power to the charger, and it should be on all the time. Green indicates a full charge, usually. If one or both of the batteries are totally dead, then the charger can't "see" them, and you will get a green light, but you will have dead batteries.
All power chairs use sealed, deep-cycle batteries. Deep cycle batteries, are designed for slow amperage dischare over a long time period, unlike a car battery that throws out a lot of amperage for turning the motor over. That's called "cold-cranking amps", and you can load-test a car battery to see if it will throw out a ton of amps for long enough to start a car. There is NO load tester made, or possible for a deep-cycle battery. A load test requires a 24-hour time period, and a complicated formula.
So, your course is to get some fresh, gel-sealed-batteries. You will need type U-1. Specify, gel-sealed-batteries when you go to the battery shop. A fresh set should get the chair up to about 12-16 mile range, which would be about 3-4 hours running constantly at high speed. Good luck.
SOURCE: headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
SOURCE: wep170 won't turn on....when charging its blue and blinking
I have the same problem? some can help us ?
