G360-2. Motherboard Asus m2r-fvm not start. 5V st.by exist. Start button works. Power supply PSU tested and IT works on 2nd PC. Capacitor PCE-71 replaced.
The hard part is this.
Start button works
what in the world does the mean, licks or all fans spin?
lets say all parts were testing on a 2nd PC and all passed
what is wrong then>? fans dead or not not told
1: mobo is dead, coin cell new and fresh. cap Plague ?
2: CPU wrong or pins bent.
3: wrong DDR or bad. test them all 1 by 1, first
4: shorted PCI cards, remove them all
5: shorted USB devices, remove them all
6: shorted HDD or DVD drive,remove them all (cables()
7: power switch cable plugged in wrong. of set or wired wrong. it's just 2 pins there.
8: the PSU has 2 power cables to mobo 4 pin and 24, both must be connected, or MOBO FAILS dead. (no damage)
VGA jack dead, an monitor tested on 2nd PC, vga igpu onboard dead. the monitor will text NO SIGNAL on a dead PC, Monitor turned on last, !!!
Apply new turmal compound to your cpu and try to start again
thermal, grease, ask how. less is more<< hint.
use only good monitor 2009 back are dead. for ccfl
use only fresh coin cell, 13years old are no good
get bios working first at VGA jack.
and 20 more causes, ask for the tests.
and that does not include, caps or any other parts that soldered down.
dead means VGA port is dead right?
SOURCE: Finding the videocard in a Fujitsu Siemens Scaleo 600 PC
firstly check the pci slot where your moniter you plug in it. and change the card.
ramesh
SOURCE: emachines doesn't start
Thank you for choosing Fixya.com
It could be a number of things but what i believe its going to be is the motherboard. The motherboard is not getting the power probally because the connections are bad. Are you getting any beep codes? or is it just powering up the fan? If it gives a beep code respond with that but i would almost bet its the motherboard.
SOURCE: Fujitsu Siemens Scenic D x86 based PC. - Waht memory do I need ?
See http://www.kingston.com and use the configurator at the top right of the page.
Telxon
SOURCE: I formated my pc and lost all my drivers, Iam a student in Ghana
I would use the application DriverAgent to scan your system for missing and outdated drivers. You can try the scan free. There is a subscription cost, if you decide you want to take advantage of the driver download capability.
Also check Internet Download Manager (IDM) for a solid way of downloading software from the internet.
Hi Kaljo Sepp, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
symptoms not told at all.
buy a dead PC? or failed out of the blue.
is RTC coin cell good? CMOS. coin.
power on works, fan blows air.
screen not dead? do you get Fujitus or ASUS mobo splash screen does monitor test on 2nd PC GOOD?? 2006 monitors are all dead now,(used that long)
that mobo is at Fujitus.com and sows ASUS mobo.
day1 new 2006 so is 13 years old and the COIN cell CMOS CR2032 is dead and HDD dead too.
but coin is first. if bad it makes BIOS fail hard and go mad (a chaos of lies and pain)
page 1 - 7 show coin here at SATA 0
a free manual is here, amazing NO? and true maker told , ASUS (the king of mobo)
https://support.ts.fujitsu.com/indexdown...
learn to test the mobo with all 4 PCI-e cards removed. use vGA mobo actual igpu port only
test with 1 stick of DDR2 ram in slot A1.
test all sticks 1 by 1, to be sure all are good. of 4 possible
test bios pages first, no HDD connected no DVD drive attached to mobo.
and yes good PSU. and 4pin and 24pin power both from PSU to mobo are mandatory. both plugs.
one more. all jumpers on mobo set correctly
BIOS hot key is key, numlock OFF
RTM above.
