Televison & Video Logo
Claire Pragnell Posted on May 06, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Hisense 355L fridge that is not getting cold. I've looked at all of the troubleshooting info and not sure where to start. All advice gratefully received!
Model HR6AFF355D
rfredey
Level 2:
Habit-Forming:
  • Expert 145 Answers
  • Posted on May 06, 2019
rfredey
Expert
Level 2:
Habit-Forming:
Answers
145
Questions
Helped
27741
Points
491
Assuming that power is connected, there is an issue with your compressor and/or Freon. If there is the proper amount of Freon in the system the compressor is supposed to compress it and make it cold. Feel the tubes. Are they cold? Can you hear the compressor kicking in? Is there a reset button on the compressor?
5 Related Answers
Anonymous
  • 59 Answers
  • Posted on May 21, 2010
SOURCE: I have a 15 year old Jenn Air Fridge/freezer Model
You will need to pull the fridge out and remove the rear lower panel. If the unit is operating you will be looking to see that the fan in the rear is also operating. Most likely it is not. You will need to replace that fan motor if it is not.
Anonymous
  • 1891 Answers
  • Posted on Jan 01, 2011
SOURCE: My Jennair refrigerator (Model #JCD2389DES)
clean the coils under the ref will help it to run less and cool better . and make sure the fan under there is going also . but the ice or frost that you found in the freezer is the problem . it has block the air flow that cools the fresh food side . this is caused by 1 ot three things . i would replace the defrost terminator on the top of the cold coil first and if this does not correct problem replace the defrost control ( timer or some times called the A D C . ) part # 6100 5988 ) the heater is pr # 61006199 and comes with the terminator . hopt this helps mm feed pack please ..
Anonymous
  • 3917 Answers
  • Posted on May 15, 2011
SOURCE: Any advice for where to
Hi
Please check the links where you can order the parts as per your requirements:-
http://www.rekitchen.com/refrigerator/brands/franklin-chef.html
http://www.repairclinic.com/Refrigerator-Parts
http://lowes.partsquik.com/
http://www.applianceparts.com/index.php?main_page=index&cPath=5&zenid=g99ne49rc8qd6hu5n1a7f9h1e2
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Anonymous
  • 1622 Answers
  • Posted on Jun 21, 2011
SOURCE: my rv fridge model (designers
Sounds like you have a defrost problem since the freezer side is working okay . It probably is not blowing cold air into the refrigerator side , so to check the defrost circuit , unplug the refrigerator and inside the refrigerator section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and forward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 Phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrigerator's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Using a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly through the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrigerator back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrigerator and reinstall the refrigerator control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired together and the replacement part comes with a new heater and bimetal already wired together . This would be the adviseable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
I hope this will help to solve the problem......
Anonymous
  • 20 Answers
  • Posted on Dec 10, 2012
SOURCE: My Mini fridge Doesn't Get Cold, it's running, I've tried unplugging it for a day and then plugging it back in , still not getting cold..Looked at back and everything looks fine..Except..T
Replace the fridge compressor with another one, try a Google search and maybe you'll find result's for your specific fridge. If all else fails, then ring up your fridge manufacturer and talk to them about your fridge, and if you still have warranty and you complain hard enough, they might just send in a new compressor.
Hi there I have an LG Icebeam Door Cooling fridge that doesnt seem to be working correctly. The fridge is not that cold and the freezer is defrosting on the top section. The light is on and it seems
Find your model # and put it in the search box here: http://www.lg.com/us/support . Once your fridge is showing, there is great troubleshooting info available. Also, armed with the model #, we can actually give you pertinent advice!
Fridge too cold
Is the thermostat on the fridge side sending the correct signals to the controller?
2answers
2answers
I need a manual for Sharp Fax Machine UX-355L
Search the Sharp USA website
http://www.sharpusa.com/CustomerSupport/search.aspx?q=ux-355l
Specifically:
UX-355L Operation Manual
fax_man_ux355l.pdf
2answers
I have a Jenn Air JCD2289AEW side by side refrigerator. The freezer has not been cooling properly for a few days. Now the refrigerator seems to be maybe less cool than it should be. I still get cold air...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
1helpful
Model HR6TFF460 (S) Contacted Hisense 21Jun10 as fridge would not cool and items in freezer were melting 24Jun10 a technician came and adjusted settings to minimum which did not make sense, if you want...
heatman101
Please can you help me my fridge peezer FFA60 FUTURE fridge freezer isnt working right, my freezer is great but my fridge seems to stop & start altough the light is still on, if I turn off plug it...
that model number does not come up in my program, so I cannot give you any concrete advice. The fact that your freezer is great is a good sign, nothing major. Sounds like you may have a bad freezer fan motor, not blowing cold air down to the fridge section. but the fact that it is intermittent like that, you might have a faulty main control board. Without proper inspection, I cant say for sure.
www.FixMyFridge.net
Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Top Hisense Televison & Video Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
