Hello Seth, for what you say, it is very feasible that your JBL, have humidity, enough to make it light again
Tip, apply hot air, with a hair dryer, at the lowest speed and at least 50 centimeters away, for two or three sessions of 30 seconds
Then, let it ventilate and test later, if the proper functioning is reestablished
I hope you solve the problem
Greetings Franco Dosil
Hola Seth, por lo que cuentas, es muy factible que tu JBL, tenga humedad, suficiente para hacer que se prenda nuevamente
Sugerencia, aplicale aire caliente, con un secador de pelo, en la velocidad mas baja y por lo menos a 50 cent?metros de distancia, por dos o tres sesiones de 30 segundos
Luego, d?jalo que se ventile y prueba mas tarde, si se restablece el buen funcionamiento
Espero que logres resolver el problema
Saludos Franco Dosil
SOURCE: Program Selector Knob keeps turning
when the knob keeps turning, it is giving you a code by the blinking red light. count the blinks. i have a manual to explain what the codes mean and how to test the parts
SOURCE: Lap top was submerged in water while turned on.
It is very possible since the hard drive is sealed. Try to place the laptop in a way that the water can come out, don't plug-in or turn it on, eject the battery and get it to the technician you desired as sooner as possible.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
SOURCE: Water Heater pilot will not turn on
replace them both!!
no warrantee is provided on anything that has been submerged in water.
too many things can go wrong once they go under water
SOURCE: JBL flip only plays while connecting to the mains
Seems the battery has gone bad prematurely. Charging circuits have to be good since the unit works fine off the adapter plugged into the mains.
SOURCE: When I turn volume high it breaks up? Jbl flip
Unfortunately it sounds like one of two things, both rude... one, the amplifier attached to the speaker exceeds the output capacity of the speaker "cone", or alternatively, the amplifier distorts the output signal when near its peak amplitude... Either way, buy quality gear and you wont have this issue. Real and true, you do get what you pay for... mostly...
