Question about Watches
Rotary chronograph wrist watch minutes and hour hand not moving
My rotary wrist watch hands are not moving, the second hands are moving showing that the battery is fine
2 Suggested Answers
SOURCE:
  • 2501 Answers
SOURCE: Watch hands not moving after battery change.
I suspect that there is a setting up procedure that needs to befollowed when the batteries have been replaced. (I had a similarproblem when I did this with my watch - although the hands were moving,they were incorrect!)
I was unable to find any instructions on their web site but if you go to their web site (/www.sekonda.co.uk/) or your own area web site for Seconda, at the top of the page you will see a store locator tab, click on this to find your local store and ask them for some instructions.
Posted on Jan 26, 2010
I just recieved a tissot pcr 200 as a gift and the large second hand is pointed to 12 doesnot move the small second dial is working as are the hour and minute hand
your watch is a chronograph or stop watch. the large second hand that is pointed at 12, it is the second hand of the stop watch, it moves when you press te upper right button and it stop on that button too. when it stops the lower button is the reset. i hope i had been helped you.
Aug 04, 2011 | Tissot PR50 Sport Chronograph # T34152852...
Why isn't the second hand on my Wenger Commando SR not working? The red seconds hand is not moving. The small seconds counter of the chronograph works and the minute and hour hands work.
The large seconds hand will remain at 12 unless you press the upper right button to start it. Pres again to stop it and press the lower button to reset it. The small seconds hand that always runs is the seconds for the time. The large seconds hand is for the stopwatch function. If you like to have it running all the time just start it and leave it running - it won't harm the watch.
Jun 02, 2010 | Swiss Army Wenger Commando 70725 Wrist...
Citizen AT03060-50E,i bobught online kind cheap than showroom so still am confused that it is original or not.. my chronograph second and minute hand stops after 1 hour,the small chronograph second hand...
The chronograph will only run for 59 minutes 59.95 seconds.
If you do not have a set on instructions for your watch, you can find one on their web site (citizen.com)
When there, click on "technical support" and the on "setting instructions" and fill in the number off the back of your watch.
Feb 01, 2010 | Citizen Eco-Drive BL5184-56L Wrist Watch
Jan 22, 2010 | Watches
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Feb 13, 2009 | Bulova Watch
How do you set and deactivate the alarm function.
I did find two authorized dealers:
www.kenmarwatches.com
www.princetownwatches.com
Contact both and request users manual fur your specific model. They must be able to help.
Jan 05, 2009 | Bulova Watch
Chronograph hand not resetting to 12 o'clock
for my victorinox, the crown out one position and the reset button (lower chronograph button) changes the minute hand and the top (start/stop button) does the 10th's of a second...crown all the way out and top (start/stop button) does 30 second intervals for the minute counter.
Feb 23, 2007 | Kenneth Cole KC1232 Wrist Watch
Analog clock not in sync with digital clock
This problem may be due to your analog hands being improperly zeroed. To find out, try this: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero. If you do this and your minute hand points to 1 o'clock, or five minutes, you will know that this is the problem. If this is the problem, you can can correct it by zeroing the hands as follows: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero, or close to it. You should also notice the letters "HR" in the lefthand digital display. This allows you to move the hour hand by rotating the crown. If the hour hand is not pointing at 12 o'clock, rotate it so that it does. 3. Push the top button once. The letters "MIN" should appear in the lefthand digital display. This allows you to move the minute hand on the large dial, and the minute and hour hands on the small UTC dial. Rotate the crown so that the minute hand points directly to 12 o'clock. 4. Push the top button again. The letters "SEC" should appear in the lefthand digital display. Rotate the crown to point the second hand directly at 12 o'clock. 5. Push the crown back into its normal position. Set the digiatl time and date in your tie zone, and your analog hands should match the digital read-out. If the zeroing of the hands is not the problem, I don't know what is wrong with the watch.
Jan 22, 2007 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Watches Logo
Top Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
