SOURCE: Sharp Electronic Organizer ZQ-6000
I couldn't find any support for this on Sharps USA website. You should contact them directly at:
1-800-BE-SHARP
SOURCE: Retrieve Password without losing data with Sharp Organizer
According to the YO-370 Operation Manual:
What To Do If You Forgot The Password -
When you have forgotten the passord for the SECRET function, you have to delete the password along with all secret data by selecting "DATA DELETION" from the Function menu. Once the password is deleted, a new password can be entered. Follow the procedure below to delete the password (and the secret data along with it).
1. Recall the Function menu (2nd, FUNCTION)
2. Select "3 DATA DELETION", and press v (3, v)
3. Select "3 SECRET DATA". (3)
The delete prompt "DELETE ? Y/N" appears
4. Press Y (To retain the data, press N)
When Y is pressed, both the password and the secret data are deleted, and the initial display for the previous mode in use will reappear on the display.
SOURCE: need a manual for a Sharp zq-570 256kb electronic
The manual is in PDF format and be found HERE.
Hope this helps,
Dolf-
SOURCE: Sharp Electronic Organizer Model ZQ-5200 how do I reset the date
I just ran across my manual. My organizer died, but here goes. You have to set the home date and time as the city's date and time for your time zone. Press Shift-Home. Select 1 to choose the City. Cities are listed according to their country. Press U for United States. Press the up or down arrow to scroll. When you see your City or one in the same time zone, input that number. If DST in effect, press shift-number for the city. To set time, select 2,or Shift-Home-2. Set the time. Press enter. Good Luck.
