SOURCE: the power button in stuck in. it won't go on.
With the power plug out of the wall,remove the screws that hold the case,so you can get to the
switch. It may have just gotten cocked and stuck
in the spring mechanism. See if you can fiddle with
it lightly, to get it unstuck. Good luck.
Testimonial: "Thanks much I'll give that a try."
SOURCE: Will Harman Kardan speakers work with a Dell? If so, how?
if it is through a headphone jack the computer will never recognize the speakers you'll have to right click on the speaker icon on your tool bar lower right corner and select adjust audio properties the click advance and select desktop speakers,
SOURCE: I NEED THIS PART FOR
Normally you can buy a universal power adapter that let you set the proper voltage, plug size and polarity, go and buy one and try or take the part to the shop to see if fits before buying, also you can go to a electronics repair shop so they can make you one, normally power adapter for this hardware is made in china and very difficult to find a proper replacement original part
SOURCE: harman kardan 7000
Check all speaker connections for shorts, and make sure all cables are secure, no change! There may be a problem in the audio output stage, at this point you will need somebody to check out the unit because the problem can be hard to locate.
SOURCE: Why can I install Adobe flash player on my HTC M8
You can not, flash no longer supports android os
