SOURCE: problem with wireless router
change your MTU in the router management pages to say 1200, if that works increase the figure to highest level where the pages load, the mtu is preventing secure content from loading - maxium transmission unit.
If that does not fix it then your ssl settings in ie will need to be reset. Download a tool to do that from here http://www.support.talktalk.net/
let me know what solves it!
SOURCE: port fowarding and remote desktop
Port forwarding is not the only thing that you have to enable to access your home network. Firstly do you just want to access your router from the outside? If that is the case enable remote login via the administration tab.
If you want to login to your computer from the outside then you must first enable remote desktop and enable port forwarding on your router.
You enable port forwarding for port 3389 which is the remote desktop port. So start port is 3389 and end port is 3389 after that set a static IP on your computer that you want to access.
You can enable remote desktop by following the directions below at the link '
http://www.microsoft.com/windowsxp/using/mobility/getstarted/enableremote.mspx
After doing this. What you do is go to the status tab of your router. Look at the IP there.
On the remote computer lauch remote desktop and enter that IP then click connect. IT will then ask you for the username and password of the computer behind the router that you want to login to. After that you should be able to get in.
If you need any clarifications regarding this you may message me and id be glad to help.
SOURCE: cant access set up wizard for d-link DI-524UP wireless router
Here is a link to the D-Link's site based wizard:
http://support.dlink.com/emulators/di524/h_wizard.html
SOURCE: belkin wireless router f5d6230-3 login error.
Because default password is not working.... Please Re-set your router in order to re configure it. Press the re set button for 1 min (tiny hole at the bottom)
Hope this info hrlps
SOURCE: setting up wireless for the first time. what's
you need to use station mode and it`s not like it`s unsecure.every network in the beginning is unsecure but you have to secure it using wep or wpa.take care
