Drills Logo
m
mouayed rushdi Posted on May 05, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dewalt D21570 red light flashing what is the problem
Cenydd Griffiths
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 28, 2022
Cenydd Griffiths
Contributor
Level 1:
Answers
Questions
Helped
1183
Points
This is a Dewalt D21570 , it has a power lead not a battery
David Baisa
Level 2:
Habit-Forming:
  • Expert 73 Answers
  • Posted on May 31, 2019
David Baisa
Expert
Level 2:
Habit-Forming:
Answers
73
Questions
6
Helped
21764
Points
170
Check battery. put a new in and works?
I have Dewalt D26501 and it will not run. I have a red light flashing at the rear of the drill, i'm getting full power but, as soon as you press the trigger, the red light flashers but, no go.
The red light flashing at the rear of your DeWalt D26501 could indicate a few different issues with the tool. Here are some potential causes and troubleshooting steps you can try:
  1. Battery issue: If you're getting full power but the tool won't run, it's possible that the battery is not delivering the correct voltage or is not making proper contact with the tool. Try removing the battery and reseating it firmly in the tool, making sure it clicks into place. If the battery is still not delivering power properly, try charging it fully or using a different battery to see if that resolves the issue.
  2. Trigger issue: If the red light flashes but the tool does not run when you press the trigger, it's possible that there is an issue with the trigger itself or with the wiring connecting it to the motor. Try checking the trigger for any visible damage or debris, and make sure it moves freely when pressed. You may also need to check the wiring connections inside the tool to ensure they are secure and not damaged.
  3. Motor issue: If neither the battery nor the trigger seem to be the issue, it's possible that there is a problem with the motor itself. This could be caused by a number of factors, including a burned-out motor or a malfunctioning component inside the tool. If this is the case, you may need to take the tool to a professional technician or contact DeWalt customer service for assistance.
Overall, troubleshooting issues with power tools can be challenging, and it's important to take appropriate safety precautions when working with them. If you're unsure about how to proceed or are not comfortable working on the tool yourself, it's best to seek professional assistance.
Dcr15 dewalt radio flashed red when plugged into wall single flash help please
Occasionally, the charger might show blinking red right to indicate bad batteries. ... This indicates that the battery already have a full charge. If charging is needed, briefly drain the batteries before trying again. If the light blinks red in about 90 seconds after battery insertion, then the battery voltage is too low.
Never owned a dewalt before is this normal Red light just flashing
Roy,
On the front of your charger, you have a menu of what the flashing lights mean. As you get used to seeing the light flashing, you will be able to tell when it is flashing faster or slower. If what you are seeing right now is a slow flash of maybe a flash every second or so, that is normal for letting you know that the battery is in the charging mode and it is charging normally. When it starts flashing faster than that, you maybe experiencing a battery problem. Hope this helps!
4answers
Dewalt charger flashing red light
Here is the manual for the charger - note on page 2 the meaning of the problem you describe - time to replace batteries (depends how old they are)
http://download.sears.com/own/00925737e.pdf
That being said, check the videos out, perhaps can get it to work after all for a while longer.
Apr 13, 2014 • Drills
7helpful
2answers
I have a DCB 101 dewalt 20V charger new and there is a red light flashing first time using it. Wondering if it.s normal and also I am looking for a free download of the owner Manual for a DCK294L3 kit...
The Dewalt charger's red light will flash while charging and go to steady red when the battery is fully charged. If you go to the Dewalt ServiceNET site at http://servicenet.dewalt.com/ you can search for the manual for any of your tools. DCK294L3 does not have a manual as that is the model number for the whole kit. Search for the model number of each of your tools and you can get the manual for them. Inside the manuals it also describes the different meanings of how the red light is flashing on your charger.
Feb 18, 2012 • Drills
CHARGER PROBLEMS
The flashing light indicates the charger is charging the battery (or attempting it) and if it never finishes charging you should try to charge a different battery, if the charger charges that one ok then the battery is bad.
I purchased a new charger for my Dewalt Cordless drill and the red light just blinks. Is this normal
They usually have a little pic on there that tells you what the blinking means. I think it is charging, but sometimes it needs a green light too. Check it out. Mine flashes all kinds of signals, when it hits a dead battery, one that won't charge, it flashes something else. It only takes an hour to charge. Is the battery getting charged at all? Hope this helps.
7helpful
When charging battery flashes red then stays on red.how long should it take to change to green?.its a dewault9130 18 volt
it doesn't change to green, the solid red light means it is fully charged, there should be a legend on the front of the charger to help you with this. If it flashes real fast the battery is malfunctioning and slow flashing is charging and again solid is fully charger.
Top Dewalt Drills Experts
Sean Wright
Sean Wright
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
