Question about Measuring Tools & Sensors
How to use a sperry dm-210a multimeter - Measuring Tools & Sensors
  • 636 Answers
Hello Anthony, I sent you a link so you can find out the manual of the tester Sperry DM-210a and another where you get an explanation of the operation
I hope you can solve your concern
Greetings Franco Dosil
Hola Anthony, te envio un link para que puedas descrgar el manual del tester Sperry DM-210a y otro donde te dan una explicacion del funcionamiento
Espero que puedas resolver tu inquietud
Saludos Franco Dosil
https://www.hunker.com/13414165/how-to-use-a-sperry-dm-210a-meter
https://greenlee-cdn.ebizcdn.com/media/52058078REV01.pdf
https://www.hunker.com/13407450/instructions-for-a-sperry-dm-210a
Posted on May 04, 2019
SOURCE:
bunnydawg
  • 5158 Answers
SOURCE: checking batteries AA D cel with a sperry DM 350A digital multimeter
dc .... no lower then the voltage range of the highest voltage of the battery.
Posted on Sep 14, 2008
  • 33 Answers
I assume a "DM-350a" is some kind of a digital multimeter. I Googled and found it might be a "A.W. Sperry DM350A 5 Function 17 Range Digital Multimeter" and looking at the ranges available on that meter, you can't really thest the battery "under load" the only reasonable way to test small batteries. the DC current only goes up to 200 milli amperes. A "C" or "D" size flashlight battery puts out 1 to 4 amps depending on conditions. That's 5 to 20 times the current readable by that meter. The volts on one of those batteries is probably 1.6 volts to 1.3 volts etc. If you live in the United States, I'd say go to Radio Shack and spend $5 to $15 and buy a battery tester like "Enercell Analog 9-Range Battery Checker, $14.99, Model 22-156, catalog # 22-156"
Then you and anyone in your family can read the instructions and test 8 or 9 different type batteries. Battery types: 1.5V button-cells, "AAA"/"N"/"AA"/"C"/"D", 6V, 9V, 12V, 15V and 22.5V..
This is not supposed to be an advertizement, and I have no interest in RadioShack,... but it's supposed to be instructional.
Small price, Good instruction to anyone who can read, and if anyone forgets, they can re-read. Testing a lot of batteries in a sitting goes very fast with these.
Differently, with the sperry, or any voltmeter, you'd have to select a resistor small enough to draw the current, and large enough not to overheat or burn, connect it and measure the loaded voltage drop, compare the voltage and current of the loaded battery, and compare it to that of a new battery, and a battery you might consider too weak for your application.. Voltage equals amps times resistance, and power equals amps squared times resistance... Really, buy a battery tester.
Regards --- GooseBay_Camper
Posted on Sep 28, 2009
SOURCE: Does the Sperry DM-350A test
yes. But you have to change the LEADS down below. One must connect into the Omega connection at the bottom (looks like an upside down horseshoe). And the meter setting is where the arrow (?) symbol is. Touch the two leads together and it should "zero out". Now you're ready to check continuity.
Posted on Dec 11, 2010
Testimonial: "That was helpful. Thanks."
  • 458 Answers
SOURCE: volt meter
If you've never used a volmeter,Google it.There is a lot of info for free.
Posted on Jun 14, 2012
bmyers_1963
  • 251 Answers
SOURCE: Why does my sperry DM6450 multimeter read "connect
Are you connecting your leads to the proper terminals on the meter? There are, what, four of them? Easy to mix up.
If it still isn't working, then you might have a bad connector on your multimeter.
Posted on Nov 03, 2014
How to install a Battery in Sperry DM6400 Multimeter
remove battery door and replace battery (9V)
http://www.testequipmentdepot.com/sperry-instruments/pdf/dm6400.pdf
Nov 06, 2016 | Measuring Tools & Sensors
Changed battery on Sperry DM-5300 and now it will not power up
Try it again, with a new, tested battery.
You likely installed a "dud" (or put it in backwards?)
Jan 23, 2015 | Televison & Video
Why does my sperry DM6450 multimeter read "connect terminal" even when both are connected?
Nov 03, 2014 | Sperry Instruments DM6450 64 Series...
Replace battery on sperry dm6400 multimeter
remove battery door and replace 9V battery
detailed explanation bellow
Apr 19, 2014 | Sperry Instruments DM6450 64 Series...
Volt meter
Jun 13, 2012 | Televison & Video
Does the Sperry DM-350A test for continuity? I can't seem to find a setting that works.
Dec 03, 2010 | Measuring Tools & Sensors
Checking batteries
Sep 26, 2009 | Sperry Instruments HST401 Voltage...
I just brought a sperry dm-350A to test the switches on my dryer I thought they would come with instructions on how to use it but it didn't. Is there a place where I can go and learn what the symbols...
Just got mine from home depot. Stick the black wire into the COM port and the red wire in the V port on the right. The red wire is the positive and the black is the ground. Touch the red tip to the positive and the black one to a ground. Turn the dial clockwise to the right and you are measuring your voltage(i left it on 200).
Jul 11, 2009 | Measuring Tools & Sensors
Checking batteries AA D cel with a sperry DM 350A digital multimeter
Sep 06, 2008 | Measuring Tools & Sensors
Measuring Tools & Sensors Logo
54 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
