Question about Health & Beauty
In a DS72K01 70 amp controller in a merit pioneer mobility scooter what does that terminals pins mean, what each pin is for?
    Top Expert:
  • Health & Beauty Master
  • 54,173 Answers
Contact Merit to inquire.
Posted on May 04, 2019
SOURCE:
  • 175 Answers
SOURCE: need to trouble shoot my merit scooter, no eletc.
This sound like a bad PC board. At the head of the tiller up where you make your speed adjustments, inside is a PC board that controls all of the functions you are describing. These most often fail due to exposure to moisture as it is an electronics board. Fortunately, they are relatively cheap, about $35.00 or so. You must remove the shroud covering the tiller, remove the speed control know and expose the board inside at the top. there should be four screws holding it in place. Remove those, unplug the wires leading to the board, and install new board, plug it in, reinstall shroud and it should be off and running.
Posted on Jan 08, 2010
TheMobilian
  • 8220 Answers
SOURCE: Require instruction book for DMA Merits
PRIDE pdf
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 19, 2010
petraman7
  • 1175 Answers
SOURCE: type of charger needed for a merit D.M.A mobility scooter
http://www.easymobilityco.com/merits_mobility_scooters.htm
Posted on Apr 23, 2010
jokerstats
  • 5 Answers
SOURCE: Pioneer Bluetooth
the pin is 0000 its the phones bluetooth pin code the code is standard use it and it will work
Posted on Apr 28, 2010
turnerscc
  • 19 Answers
SOURCE: i have applied for unemployment
If you call the NJ Unemployment office they would be able to sort it out for you.
Posted on Dec 22, 2010
What is maximum wheel size that can be used on merits challenger scooter
Only the stock size.
Merits Challenger Three and Four Wheeled Scooters - Independent ...
ilcaustralia.org.au/products/5611
Nov 30, 2016 - A rear wheel drive scooter with rear suspension, suitable for outdoor use. It is available with three or four wheels. Closed loop handles allow ...
Merits Parts - All Mobility Brands - Mobility Scooter and Power Chair ...
www.monsterscooterparts.com/mobility/mobility-brands/mehepr Merits Atlantis (P710/P7101/P7102) Power Chair Parts. ... Monster Scooter Parts carries Merits parts for all models, including scooter and power chair replacement battery chargers and battery packs. ... As an authorized Merits parts dealer, Monster Scooter Parts can help you find just the ...
Merits Health Products - scooter, power wheelchair, manual ...
www.merits.com.tw/ Merits is the professional manufacturer of health products. We specialize in scooter, wheelchair, home care bed, accessibility, patient aids and other home ...
Merits Challenger 4 Wheeled Scooter - Assistive Technology Australia
https://at-aust.org/items/6176 Nov 9, 2016 - Merits Challenger 4 Wheeled Scooter - UNAVAIL (Deleted). Learn More. Approximate Price: $4350. No supplier. (0 suppliers). For information ...
[PDF]Merits Pioneer 3 and 4 Owner's Manual.pdf - Scootaround
https://www.scootaround.com/.../merits/Merits%20Pioneer%203%20and%204%20Ow... Congratulations on the purchase of your new Pioneer 3 or 4 power scooter. We at ... tiller assembly, battery charger, and owner's manual. Contact ... Wheel Size.
maximum wheel size that can be used on merits challenger scooter Google...
Apr 05, 2017 | Health & Beauty
My dad has a merits 4 wheel pioneer that flashes 5 times what fault code is this
This flash error code for the dynamic controller indicates a park brake fault. Try moving the brake lever back and forth in each direction to clear the fault. You may have a faulty brake or brake microswitch. You can test the brake with a voltmeter. It should read 40 to 60 ohms and not shorted or open. You can test the microswitch by pushing it and checking for switch closure using a voltmeter. You need to turn the scooter on and off to clear the last fault. Hope this helps.
Mar 08, 2016 | Electric Mobility Merits Pioneer 3 Hd ...
Where is a wiring schematic for a Merits Pioneer 3 S 131 3 wheeled scooter?
You can call Tech support at Merits 800-963-7487. owners manual may have where the fuses would be. Lights could be burnt out. more likely the wires were disconnected.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Feb 10, 2016 | Electric Mobility Merits Pioneer 3 Hd ...
I have a rosd king maxi mobility scooter on the electrics at the back all the wires has come off
cant find a diagram,they arent sold anymore,if you call them they might help,hers a parts place, Merits Pioneer PT S149 Scooter Parts
Jun 12, 2015 | Cars & Trucks
Broken gears on merits pioneer 9 mobility scooter. Where can I g
sadly FIXYA has no idea other than perhaps the manufacturer .
Jan 16, 2018 | Merits Pioneer 9 Heavy Duty Scooter
Scooter won't move
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
Aug 09, 2012 | Electric Mobility Merits Electric...
Health & Beauty Logo
52 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
