The power outlet works but the machine does not appear to receive power. Is the a fuse or something I could check?
SOURCE: DISHWASHER WILL NOT POWER ON AND THERE IS POWER TO THE OUTLET
more than likely the door catch switch or the on off button, check these 2 first
SOURCE: Kenmore Dishwasher, no power
There will be a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the plastic housing.
SOURCE: Viking Designer Series DFUD041 Built-in Dishwasher
Did you try the power on button all the way to the left?
SOURCE: Not receiving power
It may be the power inverter on the TV itself.
If it's still under warranty I would call the company you bought it from and ask them to cover it for you. If it's not, get a quote from a local electronics store that deals with TV repairs.
Incase it's not the inverter and is something else inside the TV (blown capacitors , etc) I would recommend keeping it unplugged until you get it looked after.
SOURCE: When I turned on my viking 980, the power went on
More than likely it blew the fuse in the transformer, although it is fairly easy to replace this fuse it is important to find out why it blew. The transformer is under the machine and held in place by 4 screws. Take this out and ease the transformer out, it will still be hooked to the connecting wires just gently disconected them. Once you open the transformer you will see a small fuse, you can take it to radio shack and get an EXACT replacement.
I have fixed 100s of these of the last 25 years
