SOURCE: Jaccuzi hot tub will not heat?
sounds like it maybe the heater again. Have you pulled it out and checked the ohms? it should be at least 10.5 ohms
it could be the thermostat or the pressure switch - if either of those are not working it will not heat either.
SOURCE: no power to hot tub...
In all liklihood, your problem is a breakdown in the insulation of the heating element. The elements tend to be mineral insulated then metal jacketed. Once you get a bit of corrosion on the jacket and a little water gets into the mineral powder, it's insulation properties fall off sharply, shorting out the power supply.
There are two practical ways of testing this:
The pro way of doing it is to borrow a high voltage insulation tester, disconnect the power leads from the element and check the resistance between one of the elements terminals and the jacket. Treat anything less than a megohm as a failure requiring replacement of the element. (nb. This is one of those rare cases where you need to use a proper insulation tester - an ordinary multimeter often fails to find this problem)
The alternative is just to replace the element and see how much difference it makes.
A.
SOURCE: After approx 40 min of highway driving the AC stops blowing cold
This is a problem solved by moderation. There are pressure switches in the system which cut off the compressor for too high a charge and too low a charge. The unit is suppose to cycle between a predetermined range, a moderation between high and low. If you were having problems before replacing the freon there is at least 1 pressure switch that could have been your problem in the beginning. If you have a manifold guage which shows high and low pressure you can tell when the pressure switch is open or closed. Some switches and for sure the autoparts store selling them can tell you the op[erating range of your switch. You can try just replacing the low pressure switch and fly blind without the manifold guages. Know how many ounces of Freon you put in? Compare to specs to see if you overcharged.
SOURCE: maax infinity hot tub error code clfl dont have
Found at http://www.maaxcollection.com/Produits/ProductInfo.aspx?cat=1&fmly=1315&mdl=1851&sp=2%3b5%3b215
Click on "Installation Guides" under the "Downloads" blue highlighted box. Then download the "Whirlpool Installation and User Guide".
Quite sparse on error codes, but p19-23 have some.
...soon to be owner/user Maax Infinity bahtubber
