Mwe71704 -
I saw a similar problem with a vcr and it's menu years ago. It turned out to be the remote. If you can operate the unit without using the remote, try that to see if the problem happens again. If not, the remote is the issue. You don't say if there were any factors that could be traced directly to the remote (like the jump happened when you pointed the remote at the unit or pressed a button). You might also have a button that is stuck.
You'll have to do some experimenting to see if the remote is the cause, but it might be worth it. If the unit can't be operated without the remote, reboot it with the remote pointing away from it. Then turn the remote towards the unit. then try some of the functions. If it jumps to the suggestion screen, note which button you had just pressed and repeat the entire process. If a particular button always causes the issue, that's the culprit. You may want to just use the unit as you have been, rebooting as necessary, but pay attention to what happens right before the jump to the suggestion screen.
Thanks,
videoman7
