SOURCE: hot water does not come out
I pulled the water heater out of the rv and found the one way value broken and cloged.replaced with new one $9.12 and put back together.works great.
SOURCE: 2007 hot water heater leaking
You will be happier if you replace it
Repairs seldom last very long with this type of problem
SOURCE: I just bought a Jayco
Check your by-pass again. Cold water enters bottom fitting/line, and hot comes out the top fitting/line. Any valve in between should be closed, and any valve going in at bottom should be open, as well as open at top. There are a few different by-pass set-ups, so without knowing which one you have, this should guide you somewhat.
If you can describe what you see there, I can probably guide you through it.
