Question about Xerox Office Equipment & Supplies
How to solve error code 093-317 of fuji xerox versant 180, any one knows the nvn chain link number, thanks
  • Samora Cliford
    Samora Cliford Jul 24, 2019
    Replace the failed dispenser(s).and reset nvm values to 0
  • Xerox Master
  • 10,334 Answers
Https://www.justanswer.com/printers/6dy3y-xerox-700-fault-code-093-317-replace.html
Quoting from link above on internet:
Answered in 28 minutes by:
3/14/2012
Technician: Colin Vincent
As you probably have an idea it is black toner related as in there is insufficient black toner going onto the drum and the density sensor throws a toner dispenser error as a result. It's not a low toner issue as you said they are new so it has to be a dispenser issue. The toner is taken from the dispenser to the drum via an auger drive which is driven by a motor. Either it is not turning through a fault or more likely it is clogged up with old hardened toner making it bind or preventing insufficient new toner flowing through. (often happens if toner has got damp in storage at some point and it hardens in lumps when it dries)
Because the toner is extremely nasty stuff to breath and servicing the dispenser is messy and requires a toner vac to remove the old toner safely (it has special filters), i strongly recommend you get someone to take a look at the dispenser for you.
Even a technician may not want to repair a fault in the dispenser itself if it is confirmed for the reasons above. They may want to replace the dispenser as a unit.
Posted on May 04, 2019
SOURCE:
  • 2072 Answers
SOURCE: Xerox Copier Machine - Error U4
The fuser is not warming up.
On that machine under the web there is a thermal fuse on a white plastic mount, it has one screw through it.
It is most likely blown. Possibly caused by a jammed paper in the fuser.
That fusable link needs to be replaced.
Posted on Jan 02, 2008
  • 1056 Answers
SOURCE: how to reset drum counter for fuji xerox 203A
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Posted on Aug 28, 2008
SOURCE: Xerox Doc12 10-386 error code
10-386 Error
Posted on Dec 01, 2008
  • 30 Answers
SOURCE: why my Fuji Xerox C525A color lazer printer print out not clear?
hi,clean corotron wires,drum unit & mirrors.send me result.
thank you.
Posted on Jun 08, 2009
  • 33 Answers
SOURCE: for document centre c250 fuji
Defective IIt/IPS board. Is very expensive. Call you local Xerox service number and ask them for part number 160K99811 and how much it would cost to get it fixed.
Posted on Sep 08, 2010
Xerox 550 fault code 045-315 how to solve this error code please give some technics
Error Codes and Support
Web page above states:
Error Description: Drive Logic Fail Solution: 1.Recycle your printer 2.Check all connections to the Engine Control Board 3.Make sure the correct firmware is installed. 4.If the error continues replace, the Engine Control Board (MCU PWB)
Manual for free download at link below:
Fuji Xerox Color 550 Administrator Manual Page 205
Feb 08, 2018 | Xerox Office Equipment & Supplies
Xerox workcentre 6015 ni error code 092-651
Printer CM205 b error code 092-651
Options My printer FUJI XEROX CM205b is showing an error code of 092-651 with a sub code of 2080000. I have no idea what this means or how to go about fixing it. this has been a great printer and would like to fix it if possible.
Thank you for the help.
Apr 12, 2014 | Xerox WORKCENTRE 6015/Ni Color
I am getting an error message "external device error" chain link 116-311 for xerox 6204 machine
"external device error" chain link 116-311 for xerox 6204 machine how to solve the proplem
Dec 09, 2013 | Xerox Office Equipment & Supplies
For document centre c250 fuji xerox: error code 062-380 or error code 062-386
Aug 04, 2010 | Xerox CopyCentre C128 Black and White...
Open Questions:
565 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
