Question about Frigidaire Washing Machines
My stackable Frigidaire 2 speed heavy duty extra large capacity does not drain or spin what do I do
For drain check hose and pump no spin check belt if ok bad motor
SOURCE:
  • 1073 Answers
SOURCE: FRIGIDAIRE GALLERY 12 CYCLES COMMERCIAL HEAVY DUTY SUPER CAPACITY 2 SPEED MOTOR
see if you have a pump issue, pump not working something in the pump
Posted on Apr 12, 2008
geemarie
  • 876 Answers
SOURCE: belts slips off
Belt is too loose and probably needs to be replaced.
Posted on Aug 02, 2008
mgprice
  • 744 Answers
SOURCE: kenmore washers, heavy duty 80 series, no spin
Hello, Your problem is going to be with your lid switch, this is located normally either in the control panel or about half way down on the right side under the lid. This is a safety feature to stop you opening the lid while the machine is in a high spin. Once you have located the switch trace the wires back to the wire harness in the control panel. Disconnect the lid switch from the wire harness and with an ohms meter check for condinuity on pin 1 & 3 (the 2 outside pins not the middle this is a ground) You should find you have no condinuity and should replace this switch. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Posted on Oct 14, 2009
  • 714 Answers
SOURCE: During the spin cycle the washer does not drain
It won't drain If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Jan 03, 2010
  • 1937 Answers
SOURCE: kenmore heavy duty extra large capacity washer
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.13212200&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
If it neither drains nor spins, the first thing to check is the Lid Switch. This prevents the machine from draining and spinning if the lid is open.
I assume that you cannot hear the motor trying to turn.
See the following for how to access the console and Lid Switch connection.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=6f8112b458c05fcc8f6d1a4139b9a723
Following is a Whirlpool installation and maintenance PDF on top load, direct drive washers. It has a description of how to by-pass the switch.
It also has a troubleshooting guide.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf8525712
2007475cb/$FILE/L-55.pdf
To bypass the switch, you only have to disconnect the power to the washer, remove the two plastic clips from the console,
remove the two screws under the clips, tilt the console back, unplug the switch and using an short piece of insulated wire,
jump the two outermost contacts on the connector coming from the console and plug the washer back in.
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
Posted on Apr 25, 2010
Whirlpool heavy duty extra large capacity washer,washes, water drains, won't spin, makes a humming noise (not loud) when trying to spin
Are you sure it’s agitating? If it isn’t agitating or spinning, then motor coupler is most likely broken. If it is actually agitating, but not spinning, clutch may be bad or article of clear thing could be lodged between basket and tub.
Sep 21, 2018 | Whirlpool Washing Machines
Cell phone gets hot
Probably due to lots of apps running in current and background sessions. Turn some of the unneeded apps off, and understand that as you use your phone the battery will become warm as it provides the current to the phone.
Mar 31, 2015 | Frigidaire FGX831FS Washer/Dryer Laundry...
I have a frigidaire heavy duty extra large capacity 2 speed combination 3/4 horsepower.washer dryer. The washer fills,drains and spins. It does Not agitate. I can spin the tub counter clockwise. The thingy...
Hello Marjorie, thank you for your post!
From the information you have provided water will fill, drain and spin but your Frigidaire washer is not agitating. This could be a problem with your motor, belt, or pulley. Locating the problem is not a simple DIY job and I would suggest seeking assistance from a professional. They have the appropriate tools needed to disassemble your washer and prevent any future issues. I hope this information is helpful to some degree. -Matt
Mar 10, 2015 | Frigidaire Washing Machines
Hello, my Frigidaire heavy duty-extra large capacity-2 speed combination-3/4 hp motor washing machine has sprung a leak internally on the left side. How do I remove the front cover panel to troublesho
The easiest way to help you is to recommend you go to YouTube. type in Frigidaire washing machine disassembly. Repair Clinic has been the most useful for me. http://youtu.be/qcViH3Samp8 Good Luck.
Dec 21, 2014 | Frigidaire Washing Machines
The drum on my dryer seems to be stuck and is not spinning, the belt is on and seems to have the proper tension. Can someone help me get this dryer running again?
inspect the tumble dryer drum shaft - see image
inspect the dryer belt tensioner - see image listen for sound when electric motor is running
25302111-r0o5diaoq3uxmfwmdgmcujgm-1-0.jpeg 25302111-r0o5diaoq3uxmfwmdgmcujgm-1-2.jpg
Dec 01, 2014 | Frigidaire FGX831FS Washer/Dryer Laundry...
Frigidaire Gallery washer won't produce final high spin
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
Aug 14, 2014 | Frigidaire Washing Machines
I have a stackable kenmore washer dryer heavy duty extra large capacity 2 speed motor. The dryer has been making squeeling noise and has stopped toumbling around what can the problem be.
Could be the belt which connects motor and dryer drum. Could be the drum support rollers. Replace both either way -- common problem.
Jun 03, 2011 | Kenmore Dryers
Jammed agitator
Some further checking indicated a bad transmission. As the unit is 15 years old, I decided the best solution was a new machine! ..
Dec 03, 2008 | Washing Machines
Washing Machines Logo
50 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
