Question about Xerox Office Equipment & Supplies
Film that goes around the drums needs replacing, what is this part called so i can order and replace it?
Xerox docucolor 3535
SOURCE:
  • 208 Answers
SOURCE: No Magenta Color Printing, Xerox Docucolor 1632
Are the properties set correctly in the print driver.
You can turn certain colors up or down.
Does is copy magenta?
If so I would suspect the driver or the settings within the driver.
If it does not copy magenta, then I suspect a developer housing issue.
Printing only then suspect a driver issue.
Posted on Dec 10, 2007
  • 9 Answers
SOURCE: How do i reset the second bias transfer roller on a Xerox 3535
I am afraid you will have to call in a qulified xerox technitian to reset the second bais transfer roll. It need to be done via a laptop connected to the m/c. The laptop needs to have a special program which only xerox techs. have in there possetion.
George
Posted on Jun 02, 2009
  • 1316 Answers
SOURCE: How TO change paper size dc 3535
Enter in the user tools mode or mechanically in the paper cassette.
Posted on Sep 01, 2009
SOURCE: Docucolor 3535 Second Bias Transfer Roll - Replace Soon
Just plug the new one.
But you wil need to reset with diagnostic programme.
Posted on Nov 19, 2010
wrinaldo
  • 185 Answers
SOURCE: Xerox DocuColor 3535 103-208 error I accidentaly
There isn't much you can do, except perhaps buy at least one new board. But those are expensive
In this case, a better solution is to call Xerox. This correction must be done by an Authorized Xerox technician, with their proprietary laptop called a PWS.
They will run the procedure called GP-10 Replacing Billing PWBs.
Whit Item, Inc.
Posted on Nov 22, 2010
Xerox workcentre 7245 error codes 004-361
Drum motor failure.
If you have a new drum, try replacing the drums 1 by 1 and see when the error clears.
Also make sure the guide rails are in the correct position
Mar 16, 2013 | Xerox DocuColor 3535 Copier
Whit Item, Inc.
Nov 19, 2010 | Xerox DocuColor 3535 Copier
Respected sir i am having docu color 3535. the working condition is excellent. recently I faced a problem "change the drum unit". are there any possibilities to reset the drum counter. with...
Although you can not reset the counter by any buttons. You can replace the chip on the cartridge at a far less price.
Google a business called "the parts drop".
I have done business with them for years. Give them a call, ask for Britt, they will have what you need. They are simply the best people to deal with for Xerox parts. Courteous and honest.
Cant ask for more.
The chip is easy to replace.
Nov 12, 2010 | Xerox DocuColor 3535 Copier
Xerox Docucolor 3535 fault code 006-372
That is a problem with the laser or ROS polygon mirror motor.
It most likley has failed.
Google a business called The Parts Drop, call and ask for Britt.
They can help you parts wise. Its not real difficult to replace.
Oct 24, 2010 | Xerox DocuColor 3535 Copier
Xerox 3535 ero 004-361
Hi
Error code 004-361 means Drum error or Drum motor failure. You'll need to check the drum cartridges, remove the cartridges to check. Now enter DC330 [004-003] and press Start. The Drum Motor will now energize and the drive rotates. If it doesn't then measure voltage between the Drum Motor P/J210-4 (+) and GND (-), it should be +5 VDC is measured. Try measuring the voltage between the Drum Motor. If there is no voltage detected then you'll need to replace Drum Motor (PL 1.1). Hope this helps...
Daniel
Oct 11, 2010 | Xerox DocuColor 3535 Copier
Dc 3535 004-361
you have a problem with color drums motor, try to rotate in a colckwise manualy each color drums, if someone is hard to turn (comapred with a new one) replace it and problem will gone.
good luck
Aug 23, 2010 | Xerox DocuColor 3535 Copier
Jul 04, 2009 | Xerox DocuColor 3535 Copier
George
Jun 02, 2009 | Xerox DocuColor 3535 Copier
Xerox docucolor 3535 - error 010-348
Hi, you have to reset this code entering into diagnostic mode, If this fault is declared 3 times in succession, print and copy mode will be disabled. In order to clear this condition, reset NVM location 744-003 to 0. Saludos from mexico
May 10, 2009 | Xerox DocuColor 3535 Copier
Reseting drum cartridge on xerox 3535
Yes I m drincopy from Kosovo i reseting oall drum for xerox
Valdrinjashari81@hotmail.com
Nov 25, 2008 | Xerox DocuColor 3535 Copier
Open Questions:
20 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
