SOURCE: phone doesn't ring in earpiece
Only if you have an HL-10 lifter installed... you will then be able to hear three short beeps in your ear to indicate the phone is ringing.
SOURCE: my headset is grounded
pushing the jack hard may result in some connections pushed way off, and there is no contact to the speaker. Please see the nearest technician.
SOURCE: i cannot hear phone ring on avaya awh75n headset
Is the phones ringer turned up? It needs to be loud enough to make the ring detector ring.....
SOURCE: Ny headset does not beep in my ear when the phone
I had the same problem with my GN9125 headset and GN1000 remote answerer (lifter arm). There is a knob at the top end of the lifter arm contraption that adjusts "Ring Sensor Sensitivity" (yeah, NOT a very intuitive phrase!) - You have to twist the knob in the direction of the arrow to "increase the sensitivity". Twist it slowly while the phone is ringing and eventually you'll start hearing the ring in the headset. You can see diagrams in the GN1000 manual, which you can find online by googling.
The HL10 handset lifer is what notifies your headset that
you have an incoming call. If you are using the handset lifter and are not receiving the 3 short beeps in your ear piece there are a couple
different things that could be going on.
1.
The internal microphone could have gone out on
the lifter. This microphone is what sends the signal to your headset that you
have an incoming call. If the microphone is working you will hear 3 short beeps
in your headset.
2.
If the
volume is too low on your telephone, the handset lifter will not notify the
headset of an incoming call, so try turning the volume up on your phone and see
if that takes care of the problem.
3.
The HL10
handset lifter ships with a ring detector that has a 2.5mm jack on one end and
a small round microphone on the other end. This ring detector is intended for
phones that do not have the speaker located under the handset. You could try
plugging this into the back of the lifter and setting the microphone next to
where the lifter is mounted on your phone. This might help pick up the
sound of the phones ring tone.
If you are manually
lifting your handset out of the cradle and sitting it to the side instead of
using a lifter, then you will not receive the 3 short beeps in your earpiece to
notify you of an incoming call.
Good luck from Headsets Direct!
