SOURCE: the machine will quit wright after you start and
Had my TC5000 for a year and this is the first time this happened. I use it everyday. Googled "Bowflex Teadclimber error codes" and found this link download.dfxi.com/supportdocs/AM/Bowflex/BFX_TC135_AM_2008.pdf which is a pdf manual.
I'm going to try this fix now, hope it works for you and me
Here's what it says for ERR LS:
Belts stop turning and “err LS”
or “err OS” is displayed
Calibration Re-calibrate machine using Owner’s Manual
calibration procedure.
Speed sensor 1. Cycle power off and on.
2. Put the machine in calibration mode (see Calibration
procedure in Owner’s Manual) but do not
start the calibration routine.
3. Remove right rear plastic cover to view LED
diagnostics on control board.
Caution: Machine is on. Current is active!!
4. Locate LED D on the motor controller board.
LED may be lit or unlit.
5. Manually advance the treadle with your foot,
and check if LED D is blinking.
6. If LED D is not blinking, then the speed sensor
is not supplying a signal. Check that the speed
sensor wire is plugged into the motor controller
board, to the connection labeled “P1”. Check
connection of speed sensor to jumper wire.
Check speed sensor adjustment (use business
card to set gap between sensor and pulley). If
LED D still does not flash replace sensor.
I/O cables If LED D is flashing when the belts are turning
but err LS or OS persists check connections and
for signs of visible damage to any of the three I/O
cables. If no damage, check continuity using a
multi-meter. If a multi-meter is not available contact
customer service for replacement cables
and further assistance.
Mike
SOURCE: one treadle is rubbung on the upright
The rear bolts are loose. I had the same problem and found the four 3/8" bolts loose. You need to take the rear side covers off first then the rear cover to get to the bolts.
SOURCE: hey we moved my treadclimber tc5000 and now it
there could be several reasons why but i think that you have bumped a wire loose somewhere else. look and see on the control board that wires havent come loose. also check the wires from the console down to the control board. i have fixed several treadmils from people complaining about this same problem.
SOURCE: nautilus tc5000 treadclimber has e5
The E5 error code indicates the electronics on your treadmill require calibration. Recalibrate the machine per the instructions in your manual to clear this error code.
Testimonial: "Solved the problem. Thanks. Now have another one. Says "No Speed Sensor.""
SOURCE: how do you replace the breaker on a tc5000
VERY EASE DISCONNECT THE POWER CORD.
Disolder the wires with Solder Gun, change the breaker and again put solder in the terminal, please do it with carefully, and very tight the terminals.
the breaker is to side from main switch.
sincerely.
