I can get incoming calls but can't call out. I have a dial tone but once I punch numbers nothing happens
Hello Rachel, it would be good if you commented on the telephone device
you speak, make and model, in order to find a possible solution
Question, is the telephone connected to an internal telephone exchange or is it a company service? If this is the case, try to contact the telephone service provider and make the claim
If it's a cell phone, restart it, to see if the problem is corrected
I hope you can solve your concern
Greetings Franco Dosil
Hola Rachel, seria bueno que comentes de que aparato de tel?fono
hablas, marca y modelo, a efectos de encontrar un posible soluci?n
Pregunta, el tel?fono esta conectado a una central telef?nica interna o es servicio de compa??a? si es esto ultimo, trata de comunicarte con el proveedor de servicio de tel?fono y haz el reclamo
Si es un tel?fono celular, reinicialo, para ver si se corrige el problema
Espero puedas resolver tu inquietud
Saludos Franco Dosil
SOURCE: Motorola H350 - Incoming calls
there is nothing you can do about the delay as it's the time it takes for the bluetooth to send the signal to your earpiece to tell it the call is answered, the only way to stop any delay is to set your phone to auto answer in the bluetooth headphone settings or in the call settings.
SOURCE: Dial Tone but won't call out.
I just had the same problem. Try unplugging the plug from the electrical outlet for the home(base) unit and plugging back in. Fixed my problem right away.
dial tone but mobiles ahve no dial tone when making or receiving calls.....
