Door fault on a Hotpoint Aquarius WMF540, door light flashing and cannot open the door or start a cycle. Cheers, Pretty impractical woman with a screwdriver!
SOURCE: Door Won't Open
This is joyce
Have you tried to go to ge.com and download your documenton. your book. put in your model # and this will give you some info on why the door wont open. their is a reason.
let me know if you need any help, if you cant find out why, let me know and I will research it a little more and see if I can get you some help, but you may have to call a technician out to fix problem.
thanks
joyce
SOURCE: WMA 54 Hotpoint Aquarius washing machine lights flashing
the problem here is the machine is not emptying when its supposed to, you will find it is stopping at the rinse cycles. there is a sump underneath the machine that needs to be emptied. From my experiences, 9 out of 10 hotpoints that i would of repaired with the same problem as you are having is usualy caused by using the color catcher sheets, they are a disaster.
[email protected]
pallesappliancerepairs.com
SOURCE: Hotpoint WMF540 will not start. Lights keep
Had this same problem myself. To get mine to start i have to push the door to until it starts.
SOURCE: hotpoint aquarius wf101 washing machine wont start
fit new door interlock switch not too expesive parts about £15
SOURCE: I have a Hotpoint aquarius WMF540 washing machine
f01 RELATES TO A MOTOR PROBLEM , POSSIBLE CONTROL MODULE COULD CAUSE F01 TOO.
TRY THIS FIRST, " reset it : hold the 'start' button until all lights display, then press 'start' again. hold the 'start' and 'on/off' button together until it reads d-end or d-off. it doesn't always work 1st time so keep trying, good luck" If not then try the proceedure below.
unplugged the washer power supply, closed the water
- unscrewed two screws that hold the control panel
- removed the panel - you need the lid to be semi-opened
- (re-conected all connectors to fix any possible oxidation or unpluging - then tried the washer, but problem persisted)
- unscrewed all screws that hold the side cover - only the right one had actually been necessary (when standing in front of the washer)
- unscrewed all four screws hidden under the bottom cover in the front of the washer that hides also the filter (those still hold the side cover)
- unscrewed two more screws at the top back of the washer - they hold the circuit board to the washer body - it needs to be loose
- by pulling the top side of the washer up by the lid and pushing the side cover away "to the back" (with a screwdriver), see how the side cover is held by the top, remove the side cover
- observed the motor and immediately saw heavy corrosion at the ground connection (yellow-green wire) at the motor board and possible slight oxidation at one other connetion of the black wire
- using sand paper and screwdriver I've cleaned the contact together with the connector and tried the washer - still no effect
- cleaned the black wire connection with the same way
- tried the washer (spinning program) and - voila! It works!
- tried unplugging the black wire and running the spinning program - both the motor AND the pump didn't start
So, it looks to me that the problem was in an oxidation of the black wire connection - that is apparently a power supply for both the pump and the motor, that caused insufficient voltage and thus a power for the motor but probably still enough for the pump. The randomness of the problem was probably caused by humidity in the room and maybe some more factors - the washer is actually opened from the bottom so when I test the washer more times and see this as a solution, I'll probably cover the connetors with silicon to avoid corrosion or oxidation in the future.
Here are also some tips for putting all together:
When removing the side cover something fell from it inside. It was a plastic lath that is placed on the nearer edge of the cover and fits both onto the edge of the cover and the adjacent edge of the washer. It's a bit tricky to put it all back plus there is a plastic piece at the bottom of the side cover that is fixed there also very loosely and keeps falling inside when srewing the filter side screws - but this can be fixed with pliers adjusting the edge of the side cover to make the plastic to fit there tightly
http://www.servicematters.com/maytag_library/docs/16022808.pdf
Service manual, generic, to help troubleshoot.
