Does tv device have a hdmi-1 input
does laptop have a hdmi-1 output port
https://en.wikipedia.org/wiki/HDMI
SOURCE: New HP laptop wireless connection to BT1800HG router
Hi, Have you tried inputting the necessary security code to your HP laptop? Most if not all BT1800HG wireless router modem comes pre-configured to use a certain WEP code. In your HP laptop go through the WiFi configuration/Setup. Select option to use WEP security, type in required code normally found on the bottom of the BT1800HG. The numbers and/or characters below the bar code is the WEP code. Hope this be of some help/idea. Post back how things turned up or should you need additional information. Good luck and kind regards.
SOURCE: conia plasma 42inch connecting to macbook pro - ??
Hi, i also have a conia plasma (and sony 510 amp). Which video connection are you using? DVI-VGA? DVI-component? Note that the tv probably defaults to using YPBR rather than VGA so you may need to play with settings in the menu ...
SOURCE: media center drivers in vista for HP 530 to connect with plasma Problems
when i am trying to connect to a plasma TV from my laptop which is having windows vista operating system it is not responding properly do i need to install any drivers for that
SOURCE: Having a problem connecting HP G50 laptop to TV
You will have to select the input for this connection.
SOURCE: No sound on my plasma Conia TV
Check input connection first than check Speaker connection inside the Plasma
