Question about Kenwood Car Audio & Video
Kenwood BT318U Head Unit Powers on but nothing on display?
I recently installed my BT318U in my Lexus and it will power on showing Kenwood as it boots, then it will show the first input such as CD and then immediately after that the screen will not display anything. The screen doesn't completely black out but it shows nothing and no buttons will change the screen, other than holding the power button to shut it off... Any suggestions? Edit: [SOLVED] I simply plugged in my USB for my iphone and it seemed to bring it back to life and put it in a source. Now when it powers on, no problems. This is a pretty odd issue so not sure if others will be this easy of a fix..
SOURCE:
SOURCE: kenwood kvt 911 dvd head unit
I have a question. Everything is working perfectly except for there is no picture on the TV nor DVD. It was working fine until the other day when I messed around with some wires seeing if any of them were loose. Any suggestions?
Posted on Mar 26, 2008
PeskarMG
SOURCE: Powers up but black screen shows
1st - Try pressing <Fn> + <BrithnessUP> keys a few times, (on HP <Fn> key is between <Ctrl> key and <Windows> key, <BrightnessUP> key is <F8> key and <BrightnessDown> key is <F7> key. If nothing happens try the 2nd one.
2nd - Plugin external monitor, (type and size doesn't matter). Turn on your laptop. If you can see desktop on the external monitor, your drivers are o.k., The problem is your laptop display, NOT the graphic chip.
Posted on Dec 13, 2008
SOURCE: Westinghouse LCM22W2 shows a display then turns off after half a second
I have the same problem and have traced it down to a potential power supply issue.  I bought mine at Best Buy in '06 and was told today that they will test the power supply for free.  It may range from $50.00 to $100.00 depending on where you can get it.  This does not include labor for those not qualified to work with electronics.  Hope this helps you.
Posted on Jan 23, 2009
ginko
  • 19396 Answers
SOURCE: My Lg Monitor wont show screen (Power Button Flashing)
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 04, 2009
Lando93
  • 8 Answers
SOURCE: JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Posted on Jun 10, 2009
Kenwood ddx712
do you have the manual for your device.
Oct 23, 2008 | Car Audio & Video
I have a kenwood kdc 241 head unit about 4 months old which displays protect on the screen, it was new when i got the car & I removed it to install my own jvc chameleon, now I want to sell the car I...
It might be. Normally protect turns on when you have something wrong. A power wire goin in the ground or polarity of the speakers (+/- wires) are crossed or especially if 2 speaker wires are touching. If not hooking up the 2 green speaker wires for example, dont twist them together. seperate all non used wires
Jan 12, 2011 | Kenwood Car Audio & Video
Dvd screens in headrests are not getting power
The problem seems to be that the video out from the kenwood head unit is either faulty or the leads from the head unit to the monitors are faulty. Have you checked to see that the head unit when playing a DVD is set on ZONE 2 so that it transfers the video signal to the headrest monitors?
Jul 12, 2009 | Kenwood DDX-6019 Car DVD Player
Amp shuts off when switched from radio to cd
your amps rem wire is hooked to the power antenna wire on your head unit and so when you turn off the radio you would nolonger need an antenna so it powers down and would lower the antenna.Depending on the head unit you should have one output for the power antenna and one for the amp rem......If your head unit doesn't have the rem output you can wire it to the switched wire that powers your head unit but keep in mind the amp will stay on while you have the key in acc or run position even if your head unit is off.
hope this helps!
Jan 16, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood head unit CD and AUX sound not working
I fixed the sound problem with tech support from Kenwood. I had the blue wire from the Kenwood which is the antennae turn on wired to the amp turn on for the vehicle (2001 Blazer with Bose factory stereo). This is how I was told to wire it from the installation tech where I purchased the wiring harness. The tuning played fine because the Bose amp turned on when I played the tuner but when I played the cd or aux the amp turned off, thus no sound. The kenwood tech toldd me to wire the blue/white wire to the amp turn on for the vehicle so the amp would be on when ever power to the Kenwood was on. I rewired this way and everything works great now.
Jun 09, 2008 | Kenwood KDC -X815
Whole Unit blinks, only while driving!
You can call Kenwood support, they really do help!
The number is:
toll free 1-800-KENWOOD (536-9663)
Dec 20, 2007 | Kenwood KDC-MP205 CD Player
Kenwood kvt 911 dvd head unit
Dec 09, 2007 | Kenwood KVT-617DVD Car DVD Player
How to play dvd while driving
connect the pink wire to the black wire
Nov 08, 2007 | Pioneer AVIC-D3 Car DVD Player
Open Questions:
Car Audio & Video Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
