Check with these guys best place I know of to get replacement parts for tools and other various types of equipment
Unlikely brush holders will be available for any but the premium brands. If the brushes aren't available from the manufacturer or one of the many power tool spare parts suppliers to be found online there are specialists dotted around the world that specialise in electric motor repairs who will make replacement brushes to order from a drawing or from a pattern. They usually cost little more than off the shelf brushes.
SOURCE: new drive cog for mitre saw FMTC190MS
This is not a question, nor about Car speakers, as it was labeled.
SOURCE: Replacement carbon brushes, where to buy.
Just go to the Clark tools site & brushes can be bought on-line & sent to you.
http://www.clarkeusa.com/support.htm
Here is the link for you.
Best of luck
Ian Wallace
Testimonial: "Don't know why that site exists. Clarke filed for chapter 11 in Feb. 09. April 30th article in the Toledo Blade states they went out of business."
SOURCE: i need spare parts for my saw and if possible a
mastercraft 10" compound saw model #55-6802-6-- need spare parts - How do i get them.
Need center bolt for blade
SOURCE: carbon brush has broken and is stuck in so i cannot put a new one in, on Einhell sliding mitre saw
If you cannot get the carbon pieces and/or spring out of the brush holder your only option is to take the saw apart and remove the armature. From there you can either push the carbon piece(s) through or out from the other side. It will also give you a better assessment of any damage caused to the brush holder and armature contacts.
Testimonial: "Thanks, I have taken the saw apart and pushed through the broken carbon brush. Thanks for the advice"
SOURCE: i have a aeg ph38
Ohio Carbon part number for the brush is #19-015. Price is $2.50 each depending on how many you buy. There is a minimum order. We will probably not be able to supply the holder. Ohio Carbon Industries is a manufacturer and distributor of carbon brushes for nearly all electric motors. Call our sales dept. at 419-496-4456 or email them at [email protected].
