Ron's answer is probably more on point, just thought I'd add some personal experience. had a similar problem on my lawn boy this spring. pulled on the starter rope and the engine was froze (or it felt like it). finally fixed it by pulling the spark plug and spraying wd-40 into the engine. slowly got the engine to pull over after some difficulty. put the plug back in and got it started after 4 Pulls.
There's no diagram. If your drive cable is kinked it wont release properly and cause this issue. also if the adj arm pivot bushings are worn it will **** sideways and cause this issue
