- Turn off the device and wait 10 seconds.
- Press and hold the volume + button while powering on the device.
- Keep the volume + pressed until the Recovery mode starts (white screen).
- To move from one option to another, use the volume buttons. To select an option, press the ON/OFF button.
http://www.archos.com/manuals/A70_EN_v1.1.htm#zzee_link_94_1294044023
SOURCE: How do i copy .apk apps from my computer to my
Just use the provided USB cable and connect the tablet to PC. Windows will recognize it as another drive (USB Mass Storage similar as USB HDDs and USB sticks). Copy the APK file anywhere (for example to Downloads folder. Then unplug from PC and run the Files application on Archos. Browse to the directory and clicking on the APK filewill start installation process.
Testimonial: "Thanks, was easy to figure out compared to my friends Kyros. Even got that GAppsInstaller .apk installed..."
SOURCE: how do i set up
Glad to help YOU!
For your tablet, to get Yahoo! mail you have to activate POP setting; to activate pop on your Yahoo!Mail account you have to pay for it.
Now, if you once signed up for Yahoo! Mail Plus, add a new email account
to your email program with the following POP and SMTP settings:
1. Yahoo! Mail POP server: plus.pop.mail.yahoo.com
2. POP port: 995
3. POP TLS/SSL: yes
4. POP user name: your Yahoo! ID
5. password: your password
1. Yahoo! Mail SMTP server: plus.smtp.mail.yahoo.com
2. SMTP port: 465
3. SMTP TLS/SSL: yes
4. SMTP user name: your ID
5. SMTP password: your password
In case you will have some errors/problems having such settings you have to:
# Log in to Yahoo! Mail
# select OPTIONS > MAIL OPTIONS > go to POP/FORWARDING > choose VIEW POP on Yahoo!Mail Server.
Hope I was able to help you!
GOOD LUCK!
SOURCE: I have forgotten my wireless
Hi!
In order for you to remove the password, you need to reset your wireless router. You didn't mention what brand and model of your router, but anyway all routers have a "reset button" just look for it on your router. It is usually found at the back of the router and it is very small, you need a pin or anything long and thin to insert into it in order to push it for about 10 seconds.
Thanks for using fixya!
SOURCE: forgot my password pattern on
Forgot my password pattern how can I reset it back to factory for I will be able to use it
taking the battery out will do it
