Hello Ron, I sent you the link to download the user manual, there you will find the procedures for your concern
I hope you achieve your goals
Greetings Franco Dosil
Hola Ron, te envio el link para que descargues el manual de usuario, ahi encontraras los procedimientos para tu inquietud
Espero logres tus objetivos
Saludos Franco Dosil
http://manual.kenwood.com/files/B5A-0031-20.pdf
Testimonial: "Excellent response but the manual does not cover KPG111D programming. I think I figured it out - to reprogram to analog on an existing TK840 radio that has been programmed for NEXEDGE operation; first build an analog code plug - save to a data file, read the NEXEDGE program from the radio, then import the analog code plug from file and write that to the radio."
Hello Ron, Thank you very much for your comment and I am very happy that you have found the solution, Very Good, also thank you very much for sharing your achievement
I hope you enjoy your communications
Hola Ron, Muchas gracias por su comentario y me alegra mucho que usted haya encontrado la soluci?n, Muy Bien, tambi?n muchas gracias por compartir su logro
Espero que disfrute de sus comunicaciones
SOURCE: Can't program digital channels only has analog option
If your TV does not have a digital tuner, you'll need a digital converter box.
After the digital switch in June, did you have channels then? If so just do a rescan.
