Question about Watches
How do I download user manual for smart bracelet( band) watch
SOURCE:
VOTIT
  • 2071 Answers
SOURCE: watch band missing link
Hi lovingdesert ,the only thing you do is go to a service center for watch,if they have clasp like of your Anne Klein,maybe they have an extra. sometimes customer leave thier adjusted clasp. or go to Anne Klein site,and order an extra clasp.
Posted on Jun 17, 2008
escapement
  • 2338 Answers
SOURCE: Can not figure out how to remove links from Casio watch band
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Apr 01, 2009
SOURCE: Replacement bracelet for Tag Heur 6000 series, model #WH1151.BD0678
Perhaps this replica watch and strap would fit. It's $295
http://www.salesreplicawatch.com/Tag_Heuer_6000_Series_Mens_Watch_WH1153.BD0678.html
Posted on Aug 26, 2009
  • 183 Answers
SOURCE: how to make a relic watch bracelet a little smaller?
No but if this is a mens watch there might be a micro adjustment on the clasp. To adjust press the pin in the clasp and move the pin in or out depending on the position of the pin to make loose or tight.
Posted on Sep 19, 2009
Testimonial: "looks like you were right!"
  • 103 Answers
SOURCE: Size watch bracelet
your band is Skagen Signature Mesh
http://www.skagen.com/service/watchInstructions.fx#adjustment
Posted on Aug 04, 2010
Link removal from bracelet?
    1. Use the steps below to remove your band. You must separate the Link Bracelet into two pieces before removing the band from your Apple Watch. While removing the band, don't force the band or twist it. Use the steps below to avoid damaging the band or clasp.Jun 19, 2015
      Remove the Link Bracelet on your Apple Watch - Apple ...
      https://support.apple.com/en-us/HT204831 Apple Inc.
    Feedback
  1. How to resize or remove links from your Magnetic Bracelet ...
Jan 01, 2016 | Watches
From where i can buy a bracelet for Tissot PR 50.
mcdevito75 here, Ebay is a great place for your Tissot watch band, or you can check with any small watch repair shop in your area, specially if you want a band directly from Tissot.
Oct 26, 2010 | Tissot PR50 Titanium Large Bracelet Watch...
I have a Relic watch that is probably 20 or 30 years old. It still runs well, but the bracelet band is broken. I live in Monroeville, PA. Where can I get the band replaced?
mcdevito75 Here, You can go to Ebay or simply look for a small watch repair shop in your area for a new Bracelet for your Reic watch.
Sep 24, 2010 | Relic Watches
How do you adjust the steel watch band of a Citizen Sky Hawk A-T? JY0000-53E
    Making the Band Shorter
  1. Step 1 Stand the bracelet up on its side. Look for arrows on the inside of the bracelet.
  2. Step 2 Insert a small pointed tool from your hobby or watch set into the tiny holes on the edge of the bracelet. Insert the tool in the hole at the base of the arrow. You will see two holes on the edge of the band. Both pins need to be removed.
  3. Step 3 Push the pin out with force in the direction the arrow is pointing. Repeat this process on the second pin. When the pins are removed the link will be loose.
  4. Step 4 Remove the link from its neighbor and replace one pin to secure the bracelet.
  5. Making the Band Longer
  6. Step 1 Remove the link closest to the clasp by putting a small, pointed tool into the tiny hole on the edge of the watch band.
  7. Step 2 Push the pin out so the link is detached from the clasp.
  8. Step 3 Put a new link next to the detached link and line them up so a new pin can go through their holes and attach them together. You may need to snap them together depending on the type of Citizen bracelet you have.
  9. Step 4 Place the pin into the hole on the edge of the band and push the pin through the band with your sharp tool to attach the two links.
  10. Step 5 Repeat this process if you need to attach more than one link.
Aug 14, 2010 | Citizen Watches
Puma PU100041004 Watch Black Leather bracelet replacement/repair
mcdevito75 here, BEST BET, look for a small watch repair shop in your area for a replacement band.
Jul 10, 2010 | Puma PL1050
After buying this model watch bracelet links are rusted and torn with one year of purchasing. When i took that watch to the show room where i purchased. They kept it for 40 days saying that they has to...
mcdevito75 here, Many watches built today are not comming out with replacement Bands (straps, Bracelets) from the factory, the cost of makeing and keeping extra bands on hand is too high, they should at least have a few extra links to replace worn ones. Chances are your warantee is over on the watch and in that case, you"ll have to find another band, Bracelet on your own. Best Bet, visit a small watch repair shop in your area for another bracelet, band, Strap.
Jun 29, 2010 | Watches
My gunmetal titanium band (only half of the band is broken, what do I need to get it repaired or replaced???
some watches provides bracelet parts to replace, like rado, tissot etc...otherwise you have to replace whole bracelet, as per my experience titanium cant be solder nor repair
Feb 23, 2010 | Skagen Signature Mesh watch
How do you adjust the band on a rolex watch
Unscrew bracelet screws from the side and take out/add link. Then screw bracelet screws back.
Jan 29, 2010 | Rolex Day-Date President 118239 Wristwatch
Need pin for band on Fossil Am 3754
Measure distance between the lugs of your watch. Find the nearest watchmaker and ask for spring lug of that size (this is if you need to attach band to watch).
If you need a pin for bracelet links- measure width of bracelet and ask for split pin of that size.
Dec 18, 2008 | Fossil Watches
Geneva watch bracelet
I Have a Geneva Made Pga Tour Partners Club watch that needs a new band and I have not been able to find one.It is a special band and the PGA partners club says they are no longer available and were not helpful in finding a band.
Apr 01, 2008 | Geneva J06345 Wrist Watch
Watches Logo
54 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
